LED Indicator Upgrade?
MotoCP
Has thanked: 151 times
Been thanked: 626 times
Post by MotoCP »
Evening all.
I’m toying with the idea of removing the standard indicators from my old Africa Twin (XRV ‘96) to modernise its looks a bit.
There’s nothing actually wrong with the existing units, in fact they’ve taken years of abuse without breakage and I’ve never even changed a bulb in the twelve years I’ve been riding the bike.
I read a review on ADVrider recently that tested a number of modern LED indicators but an old Honda bulb type indicator won the test giving the brightest and best all round spread of light.
So, any thoughts/recommendations for an upgrade?
I’m aware I will also need to swap out the relay so I don’t want to waste money if the ‘upgrade’ ends up inferior in durability and practicality.
I do quite like the look of the DRC LED indicators. Anyone tried these or can recommend others?
Chris
bowber
Has thanked: 34 times
Been thanked: 179 times
Re: LED Indicator Upgrade?
Post by bowber »
Can't recommend any indicator's but if your bike only has one dash indicator you need to fit diode's in the feeds to it or the indicators won't work. Can't remember how the AT is set up.
Fried Egg Sandwich
Has thanked: 180 times
Been thanked: 65 times
Post by Fried Egg Sandwich »
Not strictly necessary to fit diodes.
I run LEDs on the back and normal bulbs on the front of my DRZ. I did have LEDs all round but they were not bright enough at the front, so I reverted the front ones to conventional bulbs.
Just had to swap out the normal flasher relay for a LED relay from eBay which cost £14, and both work fine.
Suzuki DRZ400S
BMW R1150GS
Royal Enfield Interceptor 650
Oop North John
Has thanked: 154 times
Been thanked: 199 times
Post by Oop North John »
If you do change to LED indicators, then there's ones that include a position / DRL light as well. Yamaha sell this one:
https://www.ebay.co.uk/itm/GENUINE-YAMA ... 1438.l2649
and it includes the required resistor. Loads of similar ones on Ebay that are a bit cheaper.
Andi_Archer
Has thanked: 3 times
Been thanked: 126 times
Post by Andi_Archer »
Theres these BMW style indicator which look quite good
https://www.ebay.co.uk/itm/2x-Motorcycl ... 1438.l2649
Brainfency
Post by Brainfency »
Looks preatty cool
Return to “ACCESSORIES”
