Commuting comfort:
So I have an apron leg cover for the Q4 but haven't fitted it yet just because the bike hasn't been ridden much and no commuting this year unfortunately.
But in preparation for cold weather riding I had the idea of venting the warm radiator airflow under the leg cover like simple heating. So installed a simple rotary vent from Car Builder Solutions. When the bash plate is fitted the underside will be closed off and create good pressure behind the radiator to vent up.
Next as I have done with all my bikes is I fitted a medical grade gel pad under the seat cover sandwiched under the foam pad in a carved out pocket. I used the opportunity to raise and angle the seat more backward also as I'm rather large and needed the leg room. I also reduced the size of the butt pad to give more length to the seat space. You cannot see the change unless beside a stock seat but the feel and comfort are brilliant now.
I know it's frowned on and potentially illegal but I removed the daft foot brake. The Q4 is classed as a tricycle based on the width of the rear track being less than 480mm but meaning it must have a foot brake. Well there's no room for my size 12 boots then. So that got binned (Stored) to give room and reroute the brakes for combined braking on the right lever and rear only on the left (for off roading) and much sharper brake feel with less plumbing going on. Plus my first weight saving.
I also fitted wind deflecting hand guards though I'm now contemplating more robust guards if I do more serious off roading but the need hasn't arisen for that yet. Much less likelihood of dropping the bike...
And for Christmas I'm getting (or fitting) combination running lights and indicators that do DRL and brake functions as well as indicating, for a bit more visibility. No pics yet...
I'm also getting a control module that activates the brake lights with strong engine deceleration. I know many feel a rider should use the brakes to show they're slowing down etc but I try to maintain momentum and limit how much braking I have to do, for expediency and efficiency and not waste braking life so I use the engine to slow a lot and I was surprised by how well the Q4 slows by engine braking. This is just a safety factor in my mind. I'm contemplating fitting a brake light flasher module also so that when I actually also grab the brake lever the lights will flash to warn drivers behind further. 4 wheel braking is rather effective after all...
I fitted LED dipped (with cooling) and main beam bulbs which transformed the light output and are fantastic. I'm not a fan of having 4 sets of LED spots to blind every living thing in my path and these are more than effective. No pics except light output colour is cooler than the stock halogen lights and matches the simple LED running lights which is a bonus.
The next mod I started was to buy a similar set of adjustable brake levers and I looked at modifying them to fit but the work involved would have kept me from the weekend ride so that got put on the back burner. But I'm itching to get that done as it'll really help the 2 finger braking control with combined braking on the right lever.
Update, levers modified and fitted (but handlebars not reassembled yet...) Levers feel great and work well, ready to test ride once the rest of the bike is back together.
- RHS adjustable brake lever
- IMG_20201227_160301693.jpg (156.72 KiB) Viewed 236 times
I'll update the picture when fully reassembled.
More to come.
Tyler
