701 enduro buying advice
Scrumpymonkey
Has thanked: 18 times
Post by Scrumpymonkey » Tue Sep 01, 2020 3:44 pm
Looking at a 2017 701 enduro on ebay. Sure some of you may have seen it, 4k on the clock and going for an attractive price.
Couple of things I'd welcome thoughts on.
1. Exhaust header looks pretty corroded which I find quite surprising on a 3 year old bike.
2. Fork seals required replacing at a recent service, again surprised on a 3 year old, low mileage bike.
3. Front brake needed service and fluid at the same time as it was pretty much shot.
Apprently, previous owner was a TRF member so it's been used off road which I'm not worried about but the 3 points that I'm concerned about suggest the bike has been ridden hard and/ or hasn't been well maintained.
The current owner has been open about these issues and rectified 2&3 however the header is still a bit concerning.
All these added up and also make me think that there may be more wear and tear that isn't visible in the photos.
It wouldn't be too much of an issue if the bike was just down the road but it's 250 miles away so can't just pop and see it.
So thoughts?
petecam
Has thanked: 30 times
Been thanked: 49 times
Re: 701 enduro buying advice
Post by petecam » Tue Sep 01, 2020 4:24 pm
I would have thought the headers would be stainless but maybe someone else can confirm... ? Often they get baked on mud that looks like rust, its pretty hard to remove unless you sit there for hours with a soft wire brush.
Fork seals will depend on the riding location and how it was cleaned after....I generally find KTM based products pretty good on seals but I don’t know what’s fitted to the 701...... I had a similar 690 Enduro and there were never changed on that.
To be honest I normally try and view a bike as you get a much better feel for it.......
Tonibe63
Has thanked: 778 times
Been thanked: 465 times
Post by Tonibe63 » Tue Sep 01, 2020 4:41 pm
Looks like baked on mud to me not corrosion. Harpic will fetch that off in 5 minutes.
Asgard
Has thanked: 149 times
Been thanked: 314 times
Post by Asgard » Tue Sep 01, 2020 5:16 pm
Yea headers are stainless.
Has thanked: 817 times
Been thanked: 1069 times
Post by Richard Simpson Mark II » Tue Sep 01, 2020 10:33 pm
With WP forks, it's worth depressurising the fork and also cleaning the dust boots and seals regularly.
Many folk change the seals because they are weeping, and they don't know the tricks to make them stop!
bowber
Has thanked: 31 times
Been thanked: 165 times
Post by bowber » Wed Sep 02, 2020 1:05 pm
Header is stainless but dirt gets baked on and it looks shite unless you scrub it off.
Fork seals can need changing due to dirt getting in the seals, I'd consider it a plus point that they've been changed and not just a quick "fix"with a seal cleaner, that's not to say a seal cleaner isn't worth using but seals reach a point where they just need replacing.
Front brake I'm not sure, all manufacturers recommend changing brake fluid every 2 years, I do and the old fluid does come out dirty, maybe the abs units are harder on brake fluid.
The main thing with bikes that are used off road is regular maintenance, and it sounds like the bike has had this done as needed (I've not looked at the listing)
Unless you're some riding god you can't thrash a 701 off road, they are just too powerful, the motor is very smooth and has nice bottom end power that allows you to get grip (fuel weight helps in the rear tank too) where you might not normally be able to.
Main things to look at are the clutch slave and the cam chain tensioner, they can be noisy on startup but should go relatively quiet, KTM motors are not sawing machines and have a bit more mechanical noise than a Japanese bike.
Stevied
Has thanked: 55 times
Been thanked: 16 times
Post by Stevied » Thu Sep 03, 2020 1:26 pm
I've got a 2016 for sale.
It's going on tonight.
Pm me if your interested
garyboy
Has thanked: 1592 times
Been thanked: 708 times
Post by garyboy » Thu Sep 03, 2020 6:21 pm
I wish !!!
I have started saving .. I got the ear plugs already :lol:
Stevied
Post by Stevied » Thu Sep 03, 2020 8:22 pm
I wish !!!
Do you a good deal Gary 😎
garyboy
Post by garyboy » Thu Sep 03, 2020 9:46 pm
I'm sure you would, Steve .. and you are one of the few people i would trust 8-)
but being a poor pensioner (sound of violins?) it is out of my reach atm :)
Users browsing this forum: Thedktor, Tonibe63 and 262 guests
