DR350 new toy
- Has thanked: 30 times
- Been thanked: 12 times
DR350 new toy
Picked up last night and very happy with her
Any advise on dr 350 parts,maintenance,upgrades all welcome.
Mot this week then I can get out. Acerbis plastics look great and very rare Ive been told. It’s a good starting point to build from.Any advise on dr 350 parts,maintenance,upgrades all welcome.
- boboneleg
- Has thanked: 2363 times
- Been thanked: 1407 times
Re: DR350 new toy
You could look here..................
https://www.adventurebikerider.com/foru ... 23&t=27901
btw, is that an old air-raid shelter in your garden?
one-legged adventurer
- Has thanked: 1414 times
- Been thanked: 1669 times
Re: DR350 new toy
My advise is ...
don't mess with the airbox/exhaust...with the standard kit on it will keep running up to the seat in water.
grease the suspension bearings often
Check the wheel bearings frequently, when they need replacing go for SKF...avoid cheapshit bearings. The sprocket bearing is the first to go. If it fails also check the cush rubbers...they tend to go at the same time and worn cush rubbers will kill the replacement bearing.
Clean the air filter often.
and if it's difficult to kickstart, you are probably kicking too hard! Position the piston carefully, gentle kick, no throttle and it will go first time most times.
I had one of the first in the country...ran it for 10 years and regret having got rid of it.
- Has thanked: 2452 times
- Been thanked: 3293 times
Re: DR350 new toy
It looks great - I'm sure you'll enjoy it.
Some great advice from Richard above.
It's been a while since I was riding around on my old DR350, but I do remember getting through quite a few wheel bearings.
Here's the old lady:
Re: DR350 new toy
I move in to this house in August and yes it did come with a bunker not sure what to do with it yetboboneleg wrote: ↑Sun Sep 30, 2018 2:39 pm You could look here..................
Re: DR350 new toy
Thanks for the great advice.The chap I got it off put an original air box and filter on it which is good it has got a none standard dep rear pipe but it is a proper dr 350 one it even has it stamped in it .Richard Simpson Mark II wrote: ↑Sun Sep 30, 2018 2:46 pm My advise is ...
Starting is going to take some time to get the hang of it but started it today a good few time with 4-5 kicks so I’m happy with that.not so keen on tyres it’s on road legal Cross tyres.
Re: DR350 new toy
Mine started best on super unleaded. The only times it was really hard to start was if it had been working really hard and stalled, or been upside down in a ditch (don't ask).
Practice makes perfect.
Re: DR350 new toy
Just seen the OP's bike is covered in All Balls bearings stickers!daveuprite wrote: ↑Sun Sep 30, 2018 4:03 pm It looks great - I'm sure you'll enjoy it.
When they wear out (if they haven't already)...get SKF double-seals from a bearing factor.
- Has thanked: 165 times
- Been thanked: 159 times
Re: DR350 new toy
The only thing that kills these bikes is the owners!
Keeping an eye in the oil level is important - they don't use anything significant normally but an old one might.
If you can't pull the clutch in with one (strong) finger change the cable. Suzuki only! The clutch cable has a slight downward loop where it sits on top of the engine case which can hold water and corrode the cable. You should be able to select neutral easily at a standstill.
Also short levers don't seem to work on the clutch, reducing cable pull.
Fully synthetic oil smooths the down-changes but semi is fine.
The lower shock bearing needs a regular pack with grease if you want it to last - you need to keep the water out or they rust and develop play.
All-Balls are poor quality but cheap, the Suzuki one will last a lot longer but is easily twice the price!
- Steve
Southampton area
DR350, 349, DRZ, 701
Southampton area
Re: DR350 new toy
Wow what is going on with your front brake pipe? !
It should be straight down to the lower fork, then go on the inside so it can't snag on anything.
- Steve
Southampton area
Southampton area
