Just phoned my Local Triumph dealer for a full service including shim check £752.40 of your English clebies sir
I eventually got it down to £570
anyone know of a good Triumph mechanic that can do my shim check please
cheers Spud
Tiger 955 service
- Has thanked: 201 times
- Been thanked: 272 times
Re: Tiger 955 service
- Has thanked: 337 times
- Been thanked: 153 times
thank yuou but I have already spoken to him, he do's not do older bikes anymorelancashirelad wrote: ↑Tue Aug 08, 2017 11:24 am There was a guy Muddy Sump who comes to you he is highly recommended?
www.muddysump.com
cheers Spud
I can highly recommend Dave of muddysump.
He has looked after my triumphs for the last 10
Years or so, first a street triple and now a tiger xc.
Initially at triumph north east where he was head
Mechanic, and more recently in his new mobile
Venture, muddysump.
He now has premises at Sunderland or will come
To you wherever and do whatever.
If you google muddysump he has very good and
Informative website.
I wouldn't go anywhere else.
Oops, just read last post!
Venture, muddysump.
- Has thanked: 105 times
- Been thanked: 71 times
It doesn't have to be a Triumph mechanic to do it,any bike shop could.There's nothing different about a 955 engine.I know my local bike shop's labour rates are about half the nearest Triumph dealers.
Local bike shops will do all the service bar the shims as I was told that Triumph charge them the same price for the Shims as they would any punter hence their price would be higher, and of course they would have to carry all the special tools.sprintster wrote: ↑Tue Aug 08, 2017 5:52 pm It doesn't have to be a Triumph mechanic to do it,any bike shop could.There's nothing different about a 955 engine.I know my local bike shop's labour rates are about half the nearest Triumph dealers.
So I can get it service Bar the shims, the fluids and filters I can do myself
cheers Spud
They're bullshitting you Spud.I do my own valve clearance checks and I'm no expert.For a trained mechanic it would be as quick to just remove the camshafts then no special tools would be needed.In fact if it's a 2002 or later engine the camshafts have to come out.Even if they charged £5 a shim more if they are charging £40 more per hour it would still be cheaper to go with a local bike shop.It depends on the year of your bike but the later 955 engines like mine use the same shims as a Honda CRF.I get them off ebay for about £3 each.
As I have the same bike as you this seems way too much, I was planning on doing my own shims but I expected it to be around £200 from a local dealer, what is the special tool needed. Can you borrow one
- Teflon Jnr
- Has thanked: 8 times
- Been thanked: 107 times
HOW MUCH I had my bike fully serviced in March ok its not a 955i but I had valve and shims done £7 for shims I had t30 evo tyres fitted new chain and sprockets fitted oil filters changed plugs changed etc etc and grand total of 459 of the queens English if you want I can ring them tomorrow and get you a price
The tool is for holding the valve down while you remove the shim.You can get copies for £30 on EBay or about £37 from World of Triumph.It only works on pre 2002 engines as they have the shim over the bucket.Later engines have the shim under the bucket so the camshafts have to be removed.My local bike shop reckoned on about £300 for a full service with clearance checks and throttle body balancing.
