- Landsurfer
- Been thanked: 17 times
Seem to have condensation in my instrument binnacle, anyone else ... suggested quick fix .. or warranty claim ?
Go Out. Take Risks. Live.
“ No chains shall sully thee, Thou soul of love and brav’ry “
- Has thanked: 205 times
- Been thanked: 156 times
Quite a few do it, mine too. You could join the Royal Enfield Himalayan Owners UK FB page, they have some ideas. I am hoping its a cold ambient temperature thing that will disappear when it gets a bit warmer. Its 10c here tomorrow and I'm off for a big run, report to follow.
Common fault and an easy fix. There are a couple of tutorials floating around on how to sort it - screen off and tape up the wiring port into the clocks, or something like that. It's been covered a dozen times on either advrider.com or on the Himalayan owners Facebook group. Have a search.Landsurfer wrote: ↑Sat Dec 29, 2018 3:32 pm Seem to have condensation in my instrument binnacle, anyone else ... suggested quick fix .. or warranty claim ?
https://www.facebook.com/groups/202269463693764/
https://advrider.com/f/threads/royal-en ... 0/page-271
- Landsurfer
Don't do faceberk, but taping up the ports is a good idea .. .... I'll remove the binnacle and position the port uppermost and apply some warm air to remove the moisture trapped in there ... then seal it ... many thanks ...
- Landsurfer
I am starting to have corrosion issues with the bike. Lambda sensor, frame tappings, and now the "Stainless Steel" front disc is corroding inside the swept area of the calliper.
We are not even at the "salt on the roads" time of the year yet ...
The gritters are still tied up ..
The bike is washed and WD 40'd after each ride ... my first winter looks like it's going to busy maintenance wise ...
So far the finish on mine seems to be holding up. I have done just over 3000 miles of commuting in all weathers, including the few occasions when the gritters have been out. I wash it every week or two with a wash and wax formula and spray some cheap household polish and a bit of WD40 on some of the vulnerable bits. There are a couple of bolts I have some concerns about and the quality of coating on the pannier frames does not look as good as the rest of the bike, but otherwise it seems okay. It has certainly held up better than my CCM did with the same treatment and seems easier to clean as well. I will wait and see what it is like at the end of the winter.
Cheers Jak
Cheers Jak
- Has thanked: 1414 times
- Been thanked: 1669 times
The Hyma is currently the second-best selling bike in the 125 - 600 category in the UK!
Landsurfer wrote: ↑Wed Jan 02, 2019 6:41 pm I am starting to have corrosion issues with the bike. Lambda sensor, frame tappings, and now the "Stainless Steel" front disc is corroding inside the swept area of the calliper.
I'll be the first to say it...WD40 isn't very effective. ACF-50 is the product to use.
https://ridermagazine.com/2016/09/09/ac ... la-review/
- Landsurfer
Had a look at the link you supplied ... Polar Bonding ... What does that mean ?
I'm only a professional Aerospace Engineer so have never heard of it before ...
I think I can detect the smell of ... ... Marketing ......
