- IMG_20190801_104951176.jpg (176.23 KiB) Viewed 4690 times
- IMG_20190801_104859176.jpg (205.25 KiB) Viewed 4690 times
Gazgazzler wrote: ↑Fri Sep 08, 2017 8:13 pm I also read other problems that the larger wattage bulbs were melting the lenses and the alternator struggled to keep up - No opinion on this, just what I read. I order two 35/35W bulbs from ebay.
The new switchgear turned up today, and was the more modern type (as shown above by Netsonic), for just £20. A word of warning if you try to fit it, I drilled the hole about 1-2mm too big in error, it needs to be exact size, mine does move around very slightly, but not enough to worry me. It fixed the problem of no dipped beam and extremely easy to fit
I cant get over the prices, I wonder what BMW switchgear would've cost, but then it may not have failed so soon?!?
The suspension has been set very low on the rear on mine, I bought a C spanner to adjust it (for princely sum of £3 from Quadzilla) but cant decide whether to go in LHS or RHS (when looking forward) to adjust it - both look a lot of work or is there an easier way? How many threads show roughly when its set up from factory?
Phil
HI Andi , direct from wk bikes.com, via their parts department, assuming they have them in stock !Andi_Archer wrote: ↑Thu Aug 08, 2019 3:38 pm Hi all an old thread I know but where does one get the left switchgear from?
thanks
Phil
