WK400 owners thread.
- Has thanked: 1 time
- Been thanked: 1 time
Re: WK400 owners thread.
I get very good mpg with the carb on something i didn't expect.
- IMG_20200312_152534.jpg (82.41 KiB) Viewed 2847 times
- IMG_20200312_152516.jpg (125.98 KiB) Viewed 2847 times
Took cat out of pipes and did two into one because if you lower suspension chain catches on left pipe .
Made a handy tool box out of left unused pipe.
- IMG_20200312_153308.jpg (70.83 KiB) Viewed 2846 times
Made a pin to act as a hinge
- IMG_20200312_153347.jpg (80.8 KiB) Viewed 2846 times
Got a catch from Ebay like the ones used on boxes .
- IMG_20200312_153350.jpg (96.56 KiB) Viewed 2845 times
- Been thanked: 126 times
Hi All
I have play in the rear end so does anybody have the bearing sizes for the swing arm area on a WK400 , I have dismantled the rear suspension arm to have a look and whilst the seals give the information
TC 10 24 5
TC 18 26 5
TC 18 24 5
this only relates to the seal sizes plus I would also like to replace the swing arm bearings
Any help much appreciated.
TC 10 24 5
TC 18 26 5
TC 18 24 5
OK as Im at home and cant go out riding I ended up taking it apart, measuring and ordering the following [which does not include the swing arm.]
https://www.bearingboys.co.uk/
1 of needle bearing 18 internal 24 external and 16 wide [ imprint on original NK182416]
2 off needle bearing 16 internal 24 external 20 wide - should be 22 wide but they didnt have any and I can see it making much difference
[ imprint on original NA6901]
2 off needle bearing 18 internal 26 external 20 wide [ imprint on original NK18/20]
the casting looks a tad worn though as there's a ridge worn by the bearing on one side of both ends, I`ll fill the ridge off and see how it fits
HI Andi check out page 75 on this thread...........I did mine, word of caution even after fitting all new bearings I still had some movmentAndi_Archer wrote: ↑Tue Mar 24, 2020 1:49 pm Hi All
TC 10 24 5
TC 18 26 5
TC 18 24 5
