Nice work, need to get mine off and do the same.Markus wrote: On the Foto you see the modified gear shift lever without sharp edges:
Scotriders wrote: ↑Fri Jan 10, 2020 12:22 am Thanks for the replies about the battery.
So was out again with my mates on their CRFs and again my 400 had a couple of times when it wouldn't start after stopping for a few minutes.
I'm putting it down to overheating as it only seems to happen when it's been running high revs in 1st on tough terrain.
It just wouldn't start, to the point it was almost killing the battery.
However leaving it for 15, 20 mins it would eventually start.
I've seen a few things about oil coolers, has anyone fitted one and if so where did you get it from?
Scotriders wrote: ↑Sun Jan 12, 2020 12:15 am OK so today's issues.
Had a run through to Glasgow to meet up with the Yesbikers. The ride in front of the rally was very stop start so we didn't get too far ahead of the main procession, while sitting with the engine running the red engine warning light started flashing, I switched off to let it cool down a bit and of course it refused to start when we went to move on about five minutes later. (not a happy bunny as I ended up having to push it the full length of Sauchiehall St to catch up with the rest of the bikes and finally got it to start after another 10 min wait.
Then heading home on my way out of Glasgow it cut out in traffic and wouldn't restart so had to push it out of traffic and jump start it with my charger pack to get it running again
And the final incident, heading up the A9 sitting at a steady 70ish and the engine just cuts out, red engine light comes on and I have to coast to a stop with the clutch in. Gets the bike on to the verge takes my gloves off, have a quick look around the bike for any obvious issues, try to start it again and it bursts straight into life.
So my question is, what causes the red light to come on? Is there a temperature sensor, the lambda sensor or something else?
