Wheel bearings can normally be obtained from any reputable engineering bearing supplier, typically I use SKF which my local supplier in Stockport normally has in stock, or can get very quickly;
https://www.emmett-enterprises.com
A 'milky' texture is not uncommon and is quite normal for fork oil over time, as the unit moves through rebound air can be drawn in past the seals. Since air has water vapour eventually it contaminates the oil. You can replace the oil with suspension specific oil or even automatic transmission fluid, depends upon your preferences.
WK400 owners thread.
- Been thanked: 5 times
Re: WK400 owners thread.
Hi Netsonic,
WK 400 front wheel bearings are 6005 2RS
I recently changed mine after going through Furneaux Pelham
- 20180505_155616.jpg (127.41 KiB) Viewed 3025 times
Oops. Just checked wheel bearing boxes and I've got them the wrong way round in the above two postings.
Try this picture as marked up correctly
- 20180530_202118.jpg (68.25 KiB) Viewed 3004 times
Glenn daft question but do these come with a new dust cover or do i use the old ones ?
Just ordered the bearings front and rear, went for SKF...............but the front wheel bearing oil/dust shield appears to be 21mm ID x 47mm OD x 5mm depth..................i cant find this sizing anywhere on the interweb...............any thoughts
- Has thanked: 1404 times
- Been thanked: 652 times
Replaced many wheel bearings on enduro/trail/trial bikes, always ordered bearings with rubber shields (2RS) and always reused the old outer dust seals.
HTH
HTH
