jayaredubya wrote: ↑Tue Feb 06, 2018 9:21 amThe rally is up at £3895, the L is up at £3795 both 2017 modelsminkyhead wrote:
So in context I am 102kg And 182cm tall.
Minky does my height weight alter your thoughts on which bike?
Thanks for the advice
well for a big guy the rally feels better tbo ..i think the 250s suspension gets a bad press ..it is very very soft theres no doubt about that and with your weight and 25kg of luggage it will sag a lot and kick as it packs down from time to time .. it actually compresses wel and i never bottomed it out at all ..but it struggle like feck to get back up and on whoops and stuff it actually tops out as the rebound isnt good enough ..but staedy away it will transport you around it s no hopeless its more annoying ..the front is much better than the rear and works surprisingle well out of the box ..the actual damping in the fork is extreaml;y plush and comfy
both bikes can be improved significantly and here is the rub ....the little hondas actually cease to be as little as they look once they sit up at the back and the front the suspension is actually quite good .. but i reacon the rally is sitting well south of 930 ml seat height before sag
and the older model 250l at 890/900 ..with tyres and all it is a good 3iches higher up than standard ...but it shows how much sag is in the o/e suspension to begin with ..its unreconisable from the saggy thing in the showrooms ...honda wind the preload right down so smaller folks can sit on them ...quite misleading imho
when you do the front and rear reakon on a extra inch at the front and around three at the rear ..but be warned it is a very tall bike when done im comfy on it with a 32 inseam after sag ..it fits me well ..the rallys forks are a extra inch taller too over the L
you can always pinch a inch back with a link on the rear and drop the forks ... if needed ..
at the prices you have there ..that is the cheapest rallky ive seen ...and looks to be a bargain ...the rally 1350 under book and the l650 under book
personally as a travel bike id go for the rally every time ...and that price looks really tempting
heres daves xt660 to compare the rally really does tower above it now ..ive often said it is more like a mini tenere and it feels like a very light tenere it certainly has a commaning riding position and it rides really really nice on the tar ..and for a travel bike that is imprortant too
a by minkyhead56, on Flickr
DSC_0839[1] by minkyhead56, on Flickr
