CRF250 L thread
catcitrus
Has thanked: 95 times
Been thanked: 448 times
Re: CRF250 L thread
Post by catcitrus »
That letter from Renthal is disgusting!--there is a batch out there that is simply wrong and if fitted will allow the sprocket to slide off, or at least straddle the retaining groove-However, the chain will probably keep it running roughly in the right place--as long as the rear wheel is adjusted "in line". I would take them to court over this one--or at least trading standards as its a safety issue and needs a campaign recall.
Bojer
Has thanked: 69 times
Been thanked: 23 times
Re: CRF250 L thread
Post by Bojer »
Don't recall having to do this with a Honda but from the pics it looks like just turning the retaining plate 180 degrees would work ?
garyboy
Has thanked: 2280 times
Been thanked: 992 times
Re: CRF250 L thread
Post by garyboy »
the OP (Andrew) in `Honda crf250 uk riders` tried it all ways and it would not fit.
Renthal would have soon sussed it, otherwise.
What amazed me about the post (apart from renthal)
is that there are four positions for the locking plate shape.
(front L, front R, back L, back R)
or at least there would be if the bolt holes were not offset, (R further than L from centre)
making for just 2 possible positions.
minkyhead
Has thanked: 570 times
Been thanked: 894 times
Re: CRF250 L thread
Post by minkyhead »
theres only one possible position if you get both bol;ts in ...to prevent it being put on wrong
garyboy
Re: CRF250 L thread
Post by garyboy »
2
minkyhead
Re: CRF250 L thread
Post by minkyhead »
mmmm im not convinced ..if you try and put it on the wrong way around the bolt holes will not line up as one side is offset wider ..there are only two holes and when fitted over the splines if you have it wrong you can not get the bolts in .i dont think its possible ...
garyboy
Re: CRF250 L thread
Post by garyboy »
Flip on horizontal axis .. if the plate is flat it should fit?
garyboy
Re: CRF250 L thread
Post by garyboy »
.. and if the holes are centred on that horizontal axis. as they appear to be.
garyboy
Re: CRF250 L thread
Post by garyboy »
This has been screwing my brain cell for a day
It's all Andrews fault
All that nice mr renthal did was fuck up and cover up :)
garyboy
Re: CRF250 L thread
Post by garyboy »
The splines also appear to be symmetrical about the horizontal axis. Btw
