CRF250 L thread
garyboy
Has thanked: 2280 times
Been thanked: 992 times
Re: CRF250 L thread
Post by garyboy »
I am sure the fever will go soon
when I force myself out of my cabin
catcitrus
Has thanked: 95 times
Been thanked: 448 times
Re: CRF250 L thread
Post by catcitrus »
All the possible positions were tried (ref the facebook post)--accept that Renthal fu"£ed up--and they have admitted that there was a faulty batch out there--but the dangerous thing is that they didn't (to my knowledge) do a recall and there may well be others lurking--the design has been like that from the 80s so it fits virtually all small Hondas--I think!--at least it was like that on my 89 NX250.
fatowl
Been thanked: 64 times
Re: CRF250 L thread
Post by fatowl »
Just seen this on ADVRIDER - how to get 28hp by changing ECU to a late CBR250 one. I don't know if it works, but if it does, and I've no reason to doubt it, it's a cheap and easy fix.
http://advrider.com/index.php?threads/h ... t-34627937
minkyhead
Has thanked: 570 times
Been thanked: 894 times
Re: CRF250 L thread
Post by minkyhead »
ive seen the 250r ecu resul;ts ona older 250l engine and the results are marginal
that said the guy seems to know his stuff and if it has the higher lift exhaust cams from the cbr300 engine in place already the results should be different i think he will be right to a degree
i can tell you that the rally with a free flow and knobs put out 22hp at the rear so thats probably 25/26 in real money as knobs sap the dyno
that said there was at lift
the black is freeflow stock
the blue is ditto plus 250r ecu
its noy much in h/p but it picks up and revs much quicker off the bottom for sure ..the other downside is they are quite a lot overfueled so
it will impact on tank range noticably id think
if the 250r makes 28hp at the crank 24 on the dyno seems right ..significant as the standard older 250 puts out 18 at the wheel ..you can see the older 250 gets a significant lift ..but with the 250 ecu its not so dramatic ..but with a 38ml throttle body and higher lift cams it could well work better on the rally .it looks to get it in quicker ..but as the revs rise cant get it out ..so those different exhaust cams may just be what it needs
.you have ignition timing cps sensors and stuff to consider too .. hey but if you get a ecu off e bay for 60 quid what the heck ...they are out there ..a dyno run is 45 quid so theres not a lot to lose ..worth a punt for 100 quid id say 8-) :mrgreen:
Imagedybo 250ecu by minkyhead56, on Flickr
garyboy
Re: CRF250 L thread
Post by garyboy »
minkyhead wrote: Tue Mar 27, 2018 1:11 am
.. its noy much in h/p but it picks up and revs much quicker off the bottom for sure ..the other downside is they are quite a lot overfueled so
it will impact on tank range noticably id think ..
ah right ... so that is one consideration when designing crf250L performance ..
Economy,
East (gentle) low down torque,
Longevity of motor (and services),
so it is attractive globally?
so perhaps converting it to an endure tool is .. er .. ?
Tripster1050
Has thanked: 8 times
Been thanked: 14 times
Re: CRF250 L thread
Post by Tripster1050 »
Just bought a CRF250L 2017 for a winter bike. Standard except for heated grips but will add a few sensible stuff once its run in and I get chance.
Living near Lancaster I just need to find the Green Lanes for some gentle riding
Moo
Has thanked: 3 times
Been thanked: 5 times
Re: CRF250 L thread
Post by Moo »
Hey guys!
Just picked up a 2013 model with around 5000 miles on the clock
All pretty standard at the moment, but i love tinkering!
Got a flatland radiator brace making its way to me...
Also ordered a uniflow air filter and a moose expedition rack.
I'll be scouring this post for all the cool mods!
Does seem pretty hard to find service items in the UK
Are there any dedicated CRF250L forums in the UK?
garyboy
Re: CRF250 L thread
Post by garyboy »
probably the best mods to the crf250L are ..
bash plate
hand guards
heated grips
folding mirrors?
rear rack
panier racks, if u can find some?
knobbly tyres, to suit your riding
gear change by sprocket change/s
essential ..
change clutch plates to ebc full-size
change clutch springs to HD,,
more advanced ..
renthal bars, remove indicators and tail tidy? lighter exhaust?
change suspension .. racetech?, yss?, front and rear?
engine soup-up .. ejk/ airbox/ exhaust mod?
also ..
can alter seat height to suit .. cut down seat?, /raise suspension?, .. put forks through trees?, lower/higher rear shock?/ bar risers ? etc
(mostly std mods actually, to any trail bike)
o .. and usb charger ..
https://www.ebay.co.uk/itm/Car-Auto-Cig ... :rk:9:pf:0
https://www.ebay.co.uk/itm/CAR-CHARGER- ... rk:25:pf:0
Hugh
Has thanked: 878 times
Been thanked: 929 times
Re: CRF250 L thread
Post by Hugh »
Greetings Tripster,
If you want to find the lanes then may I suggest that you join the Trail Riders Association Ribble Valley Group, which is relatively close to your location;
https://trailriders.org/Ribble-Valley
An alternative might be the TRF which has numerous local Groups, all of which will make you most welcome. The only caveat is that folks are expected to contribute and not just turn up for the info.
A cheaper option might be to join GLASS which has their updated mapping facility Trailwise2. Although principally 4X4 orientated they welcome motorcyclists and supply many of the benefits of a biker only group;
https://www.glass-uk.org
