ccm450
stephen.packer@gmail.com
Re: ccm450
Post by stephen.packer@gmail.com » Wed Dec 02, 2015 5:38 pm
Mike54 wrote:
stephen.packer@gmail.com wrote:I've fitted a non-cush drive hub to my XT660R and to be honest I really struggle to notice the difference.
Maybe it breaks loose on wet roads a little easier? and possibly when the XT 'splutter' happens it jerks the bike a little, but it isn't that noticeable.
You as rider are unlikely to notice, its the transmission which notices.
So, what is the risk with the transmission, is it that there are extra strains put on it which risks some failure? If so, what's likely to give; chain? Sprocket wear? Gearbox bearings?
CRAIGREVO
Re: ccm450
Post by CRAIGREVO » Wed Dec 02, 2015 6:48 pm
jonny955 wrote:
CRAIGREVO wrote: So its £500 for the whole wheel with cush drive?
Yes, a complete new wheel with cush drive hub, rubbers and spacers.
Regards,
Jon
In that case if he is buying the bike with the cush drive fitted surly it should be substantially cheaper? He is paying base price for the standard bike that should include a rear wheel. Then £500 for the cush drive option. But he will only have one rear wheel :huh:
OnHellas
Has thanked: 298 times
Been thanked: 700 times
Re: ccm450
Post by OnHellas » Wed Dec 02, 2015 6:52 pm
Regards,
Jon
Maybe so, but if the buyer is happy with the deal..........
roberteagle6
Been thanked: 12 times
Re: ccm450
Post by roberteagle6 » Wed Dec 02, 2015 11:46 pm
Hi Guys, thanks for the positive comments and info re the cush drive. My understanding/thoughts (I am no mechanic) was that it would reduce stress or wear and tear on gears, chain, sprocket etc - softer uptake. I was shocked at the price and will do some negotiation before handing over the dosh. What do you think a standard rear wheel replacement would be ? as it stands I do seem to be paying for 2 rear wheels !
With regard to the adjustable pre-load, what exactly would this add ? I weigh just over 10st, so I assume the suspension will not be stressed in anyway.
micksea
Has thanked: 25 times
Been thanked: 57 times
Re: ccm450
Post by micksea » Thu Dec 03, 2015 12:29 am
It's my understanding that the constant slackening and tightening of the chain when closing,opening the throttle and changing gear causes the cogs in the gearbox to slam against each other,cracking and eventually breaking up the hardened surface of the cogs.the cushion drive helps to ease this slamming together of the cogs
Has thanked: 266 times
Been thanked: 464 times
Re: ccm450
Post by Tramp » Thu Dec 03, 2015 6:06 am
Ask them ccm what weight range the rear spring is ....std ccm644 is around a max 90kg guy...all preload does is adjust ride height. Hence folks add preload when using pillions or luggage...
My 644 has no cush drive as have all ccm models and theyve done huge mileage....depends how long you own bike oe how hard you ride it as too...chain and sprocket abuse etc...
Ask them for a tub of loctite for bolts...they are a genuine nice bike
CRAIGREVO
Re: ccm450
Post by CRAIGREVO » Thu Dec 03, 2015 7:17 am
A non cush rear wheel will set you back around £300 from somewhere like SM pro.
johnnyboxer
Has thanked: 70 times
Been thanked: 256 times
ccm450
Post by johnnyboxer » Thu Dec 03, 2015 7:21 am
Regards,
Jon
Perhaps he could get 2 rear wheels for the £500
micksea
Re: ccm450
Post by micksea » Thu Dec 03, 2015 3:01 pm
When I was looking at cush drive options IIRC the cush drive hub alone (no rim or spokes) from somewhere like talon was £550,just offering a perspective on the cost of the option from ccm
Brenhden
Has thanked: 752 times
Been thanked: 493 times
Re: ccm450
Post by Brenhden » Thu Dec 03, 2015 3:20 pm
micksea wrote:When I was looking at cush drive options IIRC the cush drive hub alone (no rim or spokes) from somewhere like talon was £550,just offering a perspective on the cost of the option from ccm
Dear god! When I got my DR350 it came with spare wheels with a cush hub! I'm sat on a fortune!
Honda CRF250 Rally.
Users browsing this forum: No registered users and 130 guests
