ok guys all you dr 350 fanatics,
DSCF3474 by stujokitty666, on Flickr[/img]
well since pic was taken at the midlands ABR rally, bike has stood, went to go for a ride last night and would not start, fuel fault.
stripped carb and blew out jets etc put back on, would only tick over with the screw wound right up, runs fine apart from that.
if i turn the fuel off revs rise until it eventually stops, would suspect slow running jet blocked but stripped carb again and definately clean as a whistle, only thing i did was replace the o rings on the fuel tube and float jet pipe as it used to leak if left with fuel turned on, thats seems to be good though !
could be crap fuel, used from an old can in the shed to put a few litres in as was almost dry.
all advice opinions gratefully recieved.
The Suzuki DR thread.
Re: The Suzuki DR thread.
It was indeedboboneleg wrote:My cells understand completelyherman wrote: The grey cells are not what they were. Simon is still riding... a CB 1300 at present which is a bit far removed.
Was it you that put me onto the bike in the beginning?
- boboneleg
- Has thanked: 2363 times
- Been thanked: 1407 times
Have you checked the float-level and is the needle worn?desmo666 wrote:ok guys all you dr 350 fanatics,
one-legged adventurer
- boboneleg
In that case I owe you a beer (thumbs)
- boboneleg
So today I stripped the front end on my DR650 to check the steering head bearings...
The bearings looked fine so I re-greased them and put it all back together...
Now down to the fun bits, first job was to fit this Bajaworx screen....
I made a slight mod to it by spacing it out at the top with some fuel hose and longer screws...
Next up was a 5.3 gallon Acerbis tank, no more filling up every 100 miles....
and finally a leather Corbin seat, second-hand and won this week on ebay (thumbs)
- Been thanked: 3 times
Hi Bob
Nice link. :cheer: Dorris Mark 2 looks great in that photo. Sorry to say 6 years of Welsh mud and a couple of Pyraneese ups,along with a French trail tour have left her looking a little less than fresh. Still runs like a watch though.
Here is one of Dorris2 cooling down in France
This one is in the Pyraneese :woohoo:
Doing the rounds on Welsh home turf Now the Africa Twin is up together Dorris should be seeing some spanner action to get her tarted up a little
Hugo
Hugo
Try again
- DRZ400002.jpg (65.36 KiB) Viewed 1166 times
- DRZ400001.jpg (61.63 KiB) Viewed 1166 times
Some more and it came with extra wheels too
- DRZ400006.jpg (91.32 KiB) Viewed 1166 times
- DRZ400005.jpg (77.26 KiB) Viewed 1166 times
