Hi Rich,
this is what I've got, an speedo box in which the nylon drive has failed , I can't remember how exactly but it's usually the tabs that wear out. I also have a nylon drive wheel which I got from Germany but suspect it originally came from China.
If it's any good to you give me a shout and we'll barter over a price.
cheers, Bob.
The Suzuki DR thread.
- boboneleg
- Has thanked: 2363 times
- Been thanked: 1407 times
- Has thanked: 8 times
- Been thanked: 96 times
Re: The Suzuki DR thread.
Looks good to me dude, as long as the metal work gear moves then its all gravy.
I've still got a fresh nylon drive gear and one that doesn't look too buggered but skips when turned because of the other gear being jammed. It looks a bit like part of the housing has broken off and jammed it
How come you got rid of the wee Dr anyway Bob?
- boboneleg
I just wanted a change Rich, whether I regret it in the long run we'll see. PM me your address and I'll send it to you, if it fixes up ok then you can decide what it's worth. How does that sound?
one-legged adventurer
That's fair enough mate, everyone gets like that sometimes. I might end up changing mine in the new year depending on how it goes this weekend with the suspension service I've done today along with everything else
I'll send you a pm in a bit.
- Has thanked: 1177 times
- Been thanked: 727 times
Morning all, I'm putting my stock tank back on my 96 DR650SE and I need to know where the petcock vacuum pipe connects to the carb (or otherwise) any ideas?
Bren
Bren
Suzuki DR200 Djebel.
- Been thanked: 126 times
Installed a set of fleabay foot pegs on mine they dont look bad
https://www.ebay.co.uk/itm/Kawasaki-Klx ... SwH71XPXxh
It’s one of those cheap Chinese one from eBay for about £18 delivered I just reshaped the bottom. I was thinking of getting a heat gun to make a lip at the top.
- 9C3FB0C3-571D-48DA-AD4B-A5057C245353.jpeg (200.46 KiB) Viewed 1826 times
- 8958675F-5330-42A7-8855-E65F6DDBD37E.jpeg (201.5 KiB) Viewed 1826 times
