Erk!! Seriously buggered them....Mad Hatter wrote: ↑Fri Mar 09, 2018 1:07 pm Not today but yesterday, I changed some wheel bearings as the old ones looked like the been reclaimed from kit that was dumped off the cost of Normandy on D-Day
- Has thanked: 8 times
- Been thanked: 96 times
I'm finding it fairly annoying that someone has bodged and neglected a nice bike like this, but its about fit and healthy again nowSteveR wrote: ↑Fri Mar 09, 2018 11:30 pmErk!! Seriously buggered them....Mad Hatter wrote: ↑Fri Mar 09, 2018 1:07 pm Not today but yesterday, I changed some wheel bearings as the old ones looked like the been reclaimed from kit that was dumped off the cost of Normandy on D-Day
Sounds like an Owner like me there....Mad Hatter wrote: ↑Sat Mar 10, 2018 12:51 amI'm finding it fairly annoying that someone has bodged and neglected a nice bike like this, but its about fit and healthy again nowSteveR wrote: ↑Fri Mar 09, 2018 11:30 pmErk!! Seriously buggered them....Mad Hatter wrote: ↑Fri Mar 09, 2018 1:07 pm Not today but yesterday, I changed some wheel bearings as the old ones looked like the been reclaimed from kit that was dumped off the cost of Normandy on D-Day
- Has thanked: 13 times
- Been thanked: 4 times
For a while now started to have battery issues and decided to get a new battery. It hold OK for a couple of months but then started to have difficulty starting the bike again. Decided to check the voltage with the bike running and the voltimeter wouldn't read more than 13 then. Decided then to get a new stator. Very easy job, just take cover out, remove old gasket and put new one, replace stator and get all together again! Battery problem solved
- Has thanked: 18 times
- Been thanked: 80 times
this is the ram x grip large as I have a s7 and it fits great , I was concerned at first that I would see my phone disappear behind me on a lane or in the wind but this thing grips very well and I can say that my phone will still be there after my ride , also when I want quick sat nav directions it flips into landscape mode easy , the sled has a usb point under the seat so I run a cable up and can keep the phone topped up or charge my go-pro batteriesi can recommend RAM XGRIP,
- 20180701_135446_resized.jpg (117.33 KiB) Viewed 2919 times
- Mikekitts81
- Has thanked: 10 times
- Been thanked: 57 times
Split the casing on the ktm 640 to find the horrors inside
and this is what a ktm 640 looks like tucked under your workbench waiting to be fixed
Needs all new bearings .. as there seems to be alot of grind going on in the bearings and can only assume they have alot of the shards of this lot in it
Also needs new piston rebore nikasil coating new piston and the con rod needs renewing as it as a few milimeters of play upwards .and this is what a ktm 640 looks like tucked under your workbench waiting to be fixed
Absolutley brilliant can hold its own on the motorway nimble through traffic great offroad better than my xcx tiger But limited luggage i need to put a rack on it for more room now going Kriega route soft bags
