CB125F 2017 tickover issues
Godspeed
Has thanked: 1605 times
Been thanked: 1274 times
Re: CB125F 2017 tickover issues
Post by Godspeed » Thu Jan 07, 2021 6:46 am
Again I know this was the cbf125 so not the same model, but I had to change my ecu as it was leaning the mixture too much when warm. Secondhand ones can be picked up for near £20... maybe worth a try?
The Meandering Moustache
Going Big and Riding Small
Honda SH300 (too fast....)
Honda SH125 (Mini-Pad)
Honda Innova ANF125 (Adventure bike) Honda Cub C90. (Enduro bike)
Hoggyf
Has thanked: 53 times
Been thanked: 39 times
Post by Hoggyf » Thu Jan 07, 2021 8:40 am
Code: Select all
Thankfully parts are cheap and I should be able to recover some money from the parts I have fitted then removed, I've an oil sensor and lambda probe on order now, I'll try that then go for an ECU but I need to speak to Honda about the ECU - in case its linked to the ignition??? Wish it had a carb, cleaning or preplacing a pilot jet is a damn sight easier :D
Then:
Honda MB5, Honda MBX125, 350LC, RGV250, MTX125, GasGas JTX250, CM 644 DS, BMW R1100S, Beta Rev3 250, Beta Rev4T, Honda XL700V Transalp, BMW F800 GS, Kawasaki Super Sherpa
Now:
Montesa 4RT, Triumph Tiger 800, Beta Alp, Montesa 315
Hoggyf
Post by Hoggyf » Sun Jan 10, 2021 12:16 pm
The saga continues, replacement oil sensor and lambda probe made no change, however I did a test with it running with the spare oil sensor connected but not in the engine so it was seeing cold oil all the time and it sits fine st about 200rpm, switch it over to the oil sensor in the engine that's hot and it immediately dies, turn it off and back on still dies, connect it back up to the cold one and its fine again, so my assumption now is having changed everything else that it must be the ecu.
Anyone know if the ecu on this would be linked to the ignition coding wise? Or can I replace the cu without having to replace the ignition set?
Then:
Now:
Has thanked: 817 times
Been thanked: 1070 times
Post by Richard Simpson Mark II » Sun Jan 10, 2021 12:21 pm
I'd just tuck the 'old' sensor out of the way on the bike somewhere with the wires attached.
Hoggyf
Post by Hoggyf » Sun Jan 10, 2021 12:58 pm
Tempted to do that but I'd like to resolve this plus it's being sold and I'd rather sell it honestly than bodge it, luckily the parts are cheap second hand
Then:
Now:
Godspeed
Post by Godspeed » Sun Jan 10, 2021 2:37 pm
No idea on the matching of the ECU to the bike, but I’ve not had that on any of my other 125s before....
Hope it works!
Hoggyf
Post by Hoggyf » Wed Jan 13, 2021 8:56 pm
It runs!!! :mrgreen:
Replaced the ecu tonight and done a couple of cold starts and several hot starts and it sits and ticks over like a Swiss watch so anyone want to buy a fuel pump, throttle body, oil temp sensor and a lambda probe for a cb125f?
Thanks for the help and advice all
Then:
Now:
Godspeed
Post by Godspeed » Thu Jan 14, 2021 7:30 am
Good news. Bizarre how these things go.
It’s one of the things I love about smaller bikes that you can replace a fair few parts for relatively little.
Enjoy!
bill_qaz
Has thanked: 531 times
Been thanked: 755 times
Post by bill_qaz » Thu Jan 14, 2021 12:44 pm
Good news you solved it.
Keep the other spares in stock as you never know :shock:
Hoggyf
Post by Hoggyf » Fri Jan 15, 2021 12:49 pm
Code: Select all
Its getting sold!! That was why I was trying to get it sorted as its my GF's and her son was using it for school but needs a car for uni, neither of us wanted to sell it with a fault so I persevered. Would have been much easier with a carb!
Then:
Now:
Users browsing this forum: Majestic-12 [Bot] and 154 guests
