Ok advice please;
I've only one original ignition key for my Honda Silverwing 600 Maxi-Scooter, where could it get a replacement key sorted for it does anyone know..? Any idea of cost..?
Thanks in advance.
mac
Advice re an ignition key
- Has thanked: 116 times
- Been thanked: 270 times
Re: Advice re an ignition key
Keys Galore? Used to use them in London in my old despatch riding days. Glasgow office.
https://www.keysgalore.co.uk/
The original supplying dealer will possibly have recorded the code, perhaps check with them first.
Timpson the shoe repairers do quite a wide range, Honda dealer/specialist or locksmith.
Found these links;
https://www.key2code.co.uk/store/c60/Ho ... _code.html#/
https://www.davidsilverspares.co.uk/VINTAGE-HONDA-KEYS/
Found these links;
If the Silverwing has HISS immobiliser it will need a HISS key blank £30-50 & keying the key to the ECU by a dealer £50ish ( can be done yourself see youtube)
- Has thanked: 689 times
- Been thanked: 898 times
I have done one for SH 300 with hiss, bought a blank key with chip, had it cut to match original at local key cutter then reprogrammed keys with jumper connector bought from ebay, quite easy to do.
- Has thanked: 571 times
- Been thanked: 892 times
Don’t let the cost of a replacement HISS key put you off.
Once you’ve lost the last one replacing both keys, ECU and a myriad of other bits gets expensive very quickly.
