Blocked Oil Screen.
SteveW
Has thanked: 265 times
Been thanked: 264 times
Blocked Oil Screen.
Post by SteveW »
I've just changed the oil and filter on my DRZ400.
Here is a picture of the "Hidden" oil screen.
I've got my own thoughts, but what do folk think would have happened if I'd have left it any longer?
Tonibe63
Has thanked: 1404 times
Been thanked: 652 times
Re: Blocked Oil Screen.
Post by Tonibe63 »
....oohhh ssshhhh111tttt
Has it ever been out in it's life?
Gearbox swarf?
SteveW
Post by SteveW »
The bike had a top end re-build.
Then 600 miles later it had a top end seizure, resulting in a new cylinder head.
I decided to change the oil today...20 miles after the new cylinder head.
The repair shop hadn't removed the bash plate (it was still full of crud). You can drain the sump with the bash plate in place, but to drain the oil from the frame or to access the "Hidden" oil screen, the bash plate has to come off.
I'm thinking....after the first re-build did the repair shop check the screen? Probably not.
Did the blocked screen result in the top end seizure 600 miles later?
Obviously the second repair shop didn't check the screen.....was I heading for another expensive repair?
Helicoptermanr22
Has thanked: 21 times
Been thanked: 131 times
Post by Helicoptermanr22 »
Is that the filter in the lower frame? If so it definitely didnt help the top end at all and probably didnt do the bottom end any flavours:((
SteveW
Post by SteveW »
Yes it's the screen from the lower frame. The bottom end is seems fine.
I'd say DRZ owners beware!
Check this screen when you change the oil and filter.
Dark Knight
Been thanked: 99 times
Post by Dark Knight »
Thats absolutely horrendous.
The oil screen will be in line immediately after the oil pump, so it is likely the oil pressure would have been down quite a bit.
Hope that you have got away with it, I would check the oil screen again after doing a few ride outs.
SteveW
Post by SteveW »
Yes, I'm going to do 10 miles or so, then replace the oil and filter....and check/clean the screen.
zimtim
Has thanked: 623 times
Been thanked: 548 times
Post by zimtim »
SteveW wrote: Sat Feb 01, 2020 5:55 pm Yes, I'm going to do 10 miles or so, then replace the oil and filter....and check/clean the screen.
was just going too suggest similar,
when i had a similar issue with the KTM it actually took 4 oil changes before i was happy that i had cleared enough i did use a cheap oil for the first 3 as normaly the oil for Ktm runs at £50 a change :shock: :shock: :shock: :shock:
boboneleg
Has thanked: 2363 times
Been thanked: 1407 times
Post by boboneleg »
This is a classic on Suzuki's Steve. As you probably know that screen can be a fecker to get undone and so a lot of people leave it with possible oil starvation to the head.
I once bought a DR350 off a bloke 'for spares' , he had done loads of work to it but didn't check that screen which resulted in a fecked engine, his loss my gain.
Are you saying that those guys who did your engine did all that work and didn't clean that screen ? if so I'd be having words :evil:
one-legged adventurer
SteveW
Post by SteveW »
No they didn't check it Bob.
No harm done though, I've got it in time, they did a good job on the actual engine work, but they don't know their way around DRZ's...they're mostly in to road bikes.....no excuse for missing this screen though.
I think it's quite common to neglect this screen, as you say it's a bit of a fecker to get out. I'd also think that some folk are unaware of it.
I'm just glad I've probably found the reason for the bike's recent woes. I'm pretty sure this screen wasn't checked after the first rebuild.
