G650GS - Adjustable rear brake lever?
Geecee68
Has thanked: 85 times
Been thanked: 40 times
Post by Geecee68 »
Hi there,
I have a 2012 BMW G650GS, and I'm searching for a way to bring up the level of the rear brake lever so its easier to use when wearing hard boots. I've been looking online for an adjustable replacement, but nothing has jumped out. I picked up one of the cheap £8 ones from Ebay to see if that might be modable in some way. I could probably do something but its not exactly elegant. Any ideas anyone?
Thank you!
OnHellas
Has thanked: 571 times
Been thanked: 892 times
Re: G650GS - Adjustable rear brake lever?
Post by OnHellas »
Have you had a look at Touratech or Wunderlich?
They have done stuff for other BMW’s in the past and may list one for the 650 single.
bill_qaz
Has thanked: 689 times
Been thanked: 898 times
Post by bill_qaz »
Would the gs one on Ebay be suitable,
https://rover.ebay.com/rover/0/0/0?mpre ... 3878772226
Elmer J Fudd
Has thanked: 77 times
Been thanked: 222 times
Post by Elmer J Fudd »
From memory (I had one in 2010/11) the brake lever is made from coated steel, so option 1 would be to cut the lever and weld on a backing to lift the lever up, linish down and paint. the small gap would be filled with weld, so would not be seen.
Option 2 would be to add something on top of the lever, maybe a rubber footpeg cover, bolted through to below.
Hope your bike is going OK, I had all sorts of issues with mine, hot non-starting being the worst, so got rid of it fairly quickly.
OnHellas
Post by OnHellas »
There was a recall to sort out the hot non start problem if I remember correctly.
May be worth the OP checking with BMW of there and outstanding recalls or product updates etc.
Geecee68
Post by Geecee68 »
bill_qaz wrote: Wed Oct 02, 2019 12:24 am Would the gs one on Ebay be suitable,
Got one of these. It's made from sub meccano grade steel. I dropped the bike on grass and it disintegrated.
Geecee68
Post by Geecee68 »
OnHellas wrote: Tue Oct 01, 2019 11:37 pm Have you had a look at Touratech or Wunderlich?
I went for the reassuringly expensive Wunderlich option after an Ebay dud. Beautifully machined and works perfectly.
