Page 1 of 3
Tesco's 10w-40 oil query
Posted: Mon Sep 02, 2019 1:27 pm
by macvisual
Was in my local Tesco's store this morning, I found they have on offer; 10w-40 motor oil Part-Synthetic, suitable for petrol & diesel engines, meets requirements of the following:
API SN/CF, ACEA/B3, A3/B4, MB 229.I
Cost is £8 for 4 litres.
So, the question is? Could I use this oil for my Suzuki DL1000 V-Strom motorcycle I wonder..??
I'm sure Part-Synthetic means the same as Semi-Synthetic...?
My Suzuki owners manual states to use; 10w-40 API SF or SG, or SH, or SJ
Cheers;
Peter
Re: Tesco's 10w-40 oil query
Posted: Mon Sep 02, 2019 1:35 pm
by Saint rob
Assuming your clutch is a wet clutch you will probably need to check if it's JASO MA compatible, otherwise you are likely to experience clutch slip.
Posted: Mon Sep 02, 2019 1:49 pm
by macvisual
Suzuki manual does state; JASO classification of MA 10w-40
Peter
Posted: Mon Sep 02, 2019 4:22 pm
by onslowe
As none of the spec abbreviations match up I would stay well clear, it's cheap for a reason.
Posted: Mon Sep 02, 2019 4:38 pm
by Steve T
It's car oil, so no good in a wet clutch motorcycle.
Steve T
Posted: Mon Sep 02, 2019 4:58 pm
by Richard Simpson Mark II
As above...it contains friction reducers and may harm your (wet) clutch.
I buggered the clutch on my GasGas by using a Synthetic oil, which made the friction plates swell up. Had to fit a complete new clutch pack.
Posted: Mon Sep 02, 2019 5:06 pm
by frenchy3
Richard Simpson Mark II wrote: ↑Mon Sep 02, 2019 4:58 pm
I was told to use ATF in the gas gas trials bike but then others said use light gear oil SAE 80
Posted: Mon Sep 02, 2019 5:10 pm
by redbikejohn
I've used cheap car oil in my xt660z once the mileage got high and I stopped worrying about it. 104k in and no clutch slip. Used car stuff in old gsxr too and no clutch slip 57k on clock.
Posted: Mon Sep 02, 2019 5:21 pm
by Tramp
If you want cheap good quality speced oil buy in 25ltr on ebay from uk distributors...just make sure its no slip additives...
Posted: Mon Sep 02, 2019 5:44 pm
frenchy3 wrote: ↑Mon Sep 02, 2019 5:06 pm
I suffered unpredictable clutch action with my Pampera for years. Difficult to set up without drag or slip...and it's meant to be self-adjusting.
then I stumbled across an American You tube, hosted by the former service manager of Gas Gas USA.
Recommended 5W-30 mineral oil car engine: which I found at an American car specialist.
Seems OK so far.
