in the future I hope to do some welding on the bike
possibly pannier frames, rack, foot stand enlarger,etc etc
I would need to disconnect the battery
but is anything else needed to be isolated?
(electronics/ cpu/ efi/ ecu/ eec/ mps/ or wotever?)
or can I just isolate the battery and blast away
welding/battery?
- Has thanked: 2280 times
- chunky butt
- Has thanked: 54 times
- Been thanked: 699 times
Re: welding/battery?
Here you go Gary
https://rover.ebay.com/rover/0/0/0?mpre ... 2383274633
I'll have a borrow when you're done
- Mickdb1
- Has thanked: 8 times
- Been thanked: 85 times
Whenever welding anything with electrics attached. It a good idea to disconnect 1 terminal on the battery and I always add an extra earth cable to both the chassis and whatever I an welding to it. Make super sure you have the best contact on yer earths to metal. You dont want the current tracking across other contacts/wires. HTHY
thankyou all for the replies .. sounds like its gonna be easier to disconnect the part and weld independently
- Has thanked: 1414 times
- Been thanked: 1669 times
Bear in mind that welding can distort both the component you are adding and the component you are adding it to. Oldschool hand-made motorcycle frames were constructed in massively strong jigs for this reason.
Watch out also for embrittlement in the areas adjacent to the weld.
Disconnect the battery.
Keep your earth as close to the weld area as possible. Should be no problems then.
Just think about where you put the earth as the current will take the path of least
resistance.
If there are connectors between where you are welding and the earth disconnect them.
resistance.
