Plenty of 'bars come drilled as standard:
Heated Grips
- OB1
- Has thanked: 746 times
- Been thanked: 342 times
Re: Heated Grips
justrtw.com
justrtw.com
Re: Heated Grips
Use the symtec pads.
https://www.windingroads.co.uk/symtec-h ... -uk?page=1
- Has thanked: 2280 times
Re: Heated Grips
the advantage witht the Symtec heated things is that they go Under the ordinary grips, so do not bulkify the grips.
a bit potchy to install but work ok as long as you get a good earth point.
the big advantage is that they draw a very low current and can be used with bikes without a battery, and small genny output.
