Yamaha Serow CDI
Hugh
Has thanked: 879 times
Been thanked: 929 times
Yamaha Serow CDI
Post by Hugh »
Johnny, electrickery problems seem endemic :lol:
So, my Yamaha Serow 225, registered 2002, 4 JG2-010D model, was parked up before Christmas as a runner but now its a non-starter :!: I get just one spark when initially cranking the engine on the starter (no kickstart model).
I too have stripped the looms back to single wiring; alternator coils, magneto coil and pickup all professionally tested and no fault found; rectifier fully operational; new battery fitted; new ignition coil fitted; plug cap removed from HT lead and still only one spark per starter operation :!:
I now suspect the CDI unit but can not find any test data, only suggestion is replacement, I did look at a friend's bike but it is a different model and therefore has a different CDI unit.
My questions are; has anybody experienced this fault and how did they fix it, does anybody have any test data, does anybody know of a reliable company that can test/replace the CDI, or does anybody have a replacement for loan or for sale :?:
Serow CDI.jpg (205.49 KiB) Viewed 3140 times
garyboy
Has thanked: 2280 times
Been thanked: 992 times
Re: Yamaha Serow CDI
Post by garyboy »
new spark plug and fresh petrol?
Hugh
Post by Hugh »
Done but thanks for suggesting.
garyboy
Post by garyboy »
clean and refit all ignition, LT, HT connectors ..at least one is ropey …. also one looks like one has got wet and could be tracking … also, replace the HT lead to spark plug ??
Hugh
Post by Hugh »
Done, just like me :lol:
garyboy
Post by garyboy »
check u kill switch is all clean and dry and good connections
also, if fitted, the stand switch
also
make sure the cdi unit is sealed well and dry!
catcitrus
Has thanked: 95 times
Been thanked: 448 times
Post by catcitrus »
The fact that its sparking once and is then dying is the worst of all faults--and its not a simple break. You have checked the coil so my suggestions are either the hall effect pick up or the CDI as you have said. Both can be difficult to test--and may appear ok statically, so my best advice is to buy secondhand parts or borrow. Try the CDI first, and then replace the Hall effect pick up. I had an odd problem with my Honda Transalp and suspected the CDI--however, it wasn't--even simpler in that it was a flap of paper getting sucked into the intake under the seat. I've since swapped over CDIs just to check that I had a working spare--and I have a spare Hall effect also. Yes its a 100 quid but any subsequent problems will be a LOT EASIER TO DIAGNOSE. CDIs can suffer from dry internal joints over time and need to be de-potted and joints checked. I know its a common problem with early Hondas but I've no idea on Serrows--best get on the ADV forum as usual--and let us know.
Hugh
Post by Hugh »
Leads re-soldered, contacts cleaned, resistance of leads tested, routing and all contacts right through the loom :evil:
You have n't got a match have you :?:
IanB
Has thanked: 1057 times
Been thanked: 194 times
Post by IanB »
Hi Hugh,
I can e mail you a full repair manual with all the test specifications, if you haven't got one already ?
Time knows no limits for days such as these.............
Hugh
Post by Hugh »
Greetings Ian,
I would be most grateful, as I don't have one. I will PM you with my email.
