tubless tyre repair which kit string or mushroom
Has thanked: 330 times
Been thanked: 634 times
Post by Tramp »
Okay ive git a bart tubless conversion on the rear wheel....now fir road tyres id use a rats tail but do thry work on knobblys like mitas e09 etc.... :lol:
Id hate to find out the hard way :o
Mike54
Has thanked: 18 times
Been thanked: 95 times
Re: tubless tyre repair on a knobbly?
Post by Mike54 »
yes of course.
Re: tubless tyre repair which kit string or mushroom
Post by Tramp »
Okay so which is best mushroom or a string and can folks whose used either recommend one thanks muchly :D ....
And yes its fir a bart tubless conversion on a knobbly rear
Treadtrader
Moderator
Has thanked: 27 times
Been thanked: 74 times
Post by Treadtrader »
If you're running tubeless a good liquid sealer can work well.
I like the mushroom plugs, more professional, but a bit of a fiddle to use correctly.
The sticky string is easier to install even if the tyres a bit muddy.
Practice in the shed is the best idea.
I carry the sticky string in my van for off road vehicles, mowers and buggies etc. works well.
bikenav
Has thanked: 1187 times
Been thanked: 761 times
Post by bikenav »
I have used the sticky strings to very good effect 3 or 4 times on conventional road tyres and attempted to use a tiptop kit once and failed but it was very old so the rubbers were difficult to work. Not tried the mushrooms but can highly recommend the strings.
r
Mike54
Post by Mike54 »
the strings are much more versatile and you can use more than one if necessary. You will need to carry a reamer, dont make the mistake of not doing.
Post by Tramp »
Cheers guys for confidence inspiring replys.. So stringy bits it is, ive a tube still for front and a compressor so yes im sure the remer is important too.... Watched some vids on best use was just unsure which type was better cor the trails application...
simonw
Has thanked: 71 times
Been thanked: 164 times
Post by simonw »
I did my first mushroom last weekend (viewtopic.php?f=22&t=47951) and it was bloody hard work to wind the mushroom in, not least of all because (unbeknown to me, because I stupidly didn't check the gear when I bought it 5 years ago) the threads were buggered on the insertion tool (which is also hard work to try to hold firmly enough when winding it in). There was a sliver of flint in the tyre, so I reamed it out a little, then plugged it. 40PSI Sunday, 10PSI by Friday (unused in the interim). Don't know if that was because my technique was poor, the hole was too big, or just mushrooms don't work very well. Since the tyre (Anakee 3) was squared off I replaced it on Friday anyway.
Heff
Has thanked: 279 times
Been thanked: 135 times
Post by Heff »
Damn :oops:
Got a puncture this afternoon on my way home after my morning fix.
Alerted by the on board tyre pressure sensors about 1 mile from home
I have the mushroom type repair kit, but couldn't find the actual puncture :ugeek:
Off to the tyre shop in the morning
Gelande/Strasse R1200Gsa Triple Black
MHsnowy
Been thanked: 12 times
Post by MHsnowy »
Ive used these with great success in my van, the wife car and my daughters car.
I don't see it wouldn't work in a bike tyre.
Its the mushroom type rubber so expands inside the tyre and makes it impossible to push out.
https://www.mandp.co.uk/stop-and-go-poc ... eless.html
