Not so much technical but..... I am moving home soon and new property has an old concrete sectional double garage at the end of the drive. Old house had a breeze block single skin garage.
I’m looking into a bespoke Timber garage and would like to know peoples thoughts, comments or better still pictures of Timber man sheds if you have any for ideas. It will be for my bikes and tools mainly. Current concrete garage 17’10” x 16’4”
Would like something warm, secure and a bit of a place to escape and relax
Garage/Shed
- Tripster1050
- Has thanked: 8 times
- Been thanked: 14 times
Re: Garage/Shed
Assuming the slab is ok and has not broken it's back put 3 courses of class b semi engineering bricks round with a dpc and ensure drainage and ground levels are good. Then build a stable block.
- Tripster1050
Re: Garage/Shed
Stable block ? Liking this idea. I’m assuming going the timber route is cheaper than brick built garage at £15k + ?herman wrote:Assuming the slab is ok and has not broken it's back put 3 courses of class b semi engineering bricks round with a dpc and ensure drainage and ground levels are good. Then build a stable block.
Re: Garage/Shed
Probably not cheaper to be fair but a single skin masonry building will condensate yet a timber frame can be insulated and the walls remain at roughly 125mm. Lighter too for that existing slab. The old concrete garage slabs were not exactly heavy duty so you need to be a bit careful at the start.
Re: Garage/Shed
Just remember to check for planning and building regulation requirements. May be exempt, may not. If you need help, were based in Shipley, West Yorks, but do work across the whole country. Give us a look
https://www.onedesignarchs.co.uk/projects
Paul
Paul
- Tripster1050
Re: Garage/Shed
Thanks Paul, I am from Bradford, Eccleshill area originally until I met the wife 10years ago. I know Shipley well as my parents still live over there. Many a day spent with nose pressed against Cobb & Jaggers window before they moved & became Ducati/Triumph dealerEarwig wrote:Just remember to check for planning and building regulation requirements. May be exempt, may not. If you need help, were based in Shipley, West Yorks, but do work across the whole country. Give us a look
Paul
- Has thanked: 571 times
- Been thanked: 892 times
Re: Garage/Shed
herman wrote: ↑Thu Dec 13, 2018 9:23 pm Probably not cheaper to be fair but a single skin masonry building will condensate yet a timber frame can be insulated and the walls remain at roughly 125mm. Lighter too for that existing slab. The old concrete garage slabs were not exactly heavy duty so you need to be a bit careful at the start.
+1. All the advice you need there I reckon.
- Has thanked: 2280 times
Re: Garage/Shed
possibly you could do outer skin of structure .. ..
timber overlap boards
battens
vapour barrier
thermally insulating blockwork
insulating layer
ply sheets
battens
vapour barrier
insulating layer
ply sheets
- Tripster1050
Re: Garage/Shed
I will, many thanks for all the advice from everyone so far. Much appreciatedCone wrote:Can I suggest you look at a company called Dunster house. Their buildings are very well put together. My dad has a summer house and it is fantastic and insulated
