Auto bike electrician in Doncaster area
Craggrat
Has thanked: 5 times
Been thanked: 2 times
Post by Craggrat »
Hi
I’m looking for a auto electrician in the Doncaster area, I need some spot lights and USB port wiring up.
I’ve got the relay n switch n cable.
Anyone know of a sparky in South Yorkshire that will sort this out.
I’ve contacted two one in donny n one in Sheffield. But as soon as l say it’s on a bike they don’t seem interested.
Teflon Jnr
Has thanked: 8 times
Been thanked: 107 times
Re: Auto bike electrician in Doncaster area
Post by Teflon Jnr »
Have you tried your local bike mechanic/shop they would do it for you.
On the other hand it is really simple to do yourself if you take your time.there only a live and a earth relays are a doddle as well shame your not my way as I'd have done it for you
Biquad
Has thanked: 47 times
Been thanked: 86 times
Post by Biquad »
Come to the Ecky Thump rally next weekend and I'll show you how to do it. You will be surprised how easy it is. The biggest problem is usually removing bodywork, locating your items and then routing the wiring.
Cheers Steve
Africa John
Has thanked: 7 times
Been thanked: 58 times
Post by Africa John »
I'm in Scunthorpe but busy until early November - at the Ecky Thump next weekend then away for half term
I've fitted sat nav, running lights and a Fuzeblock terminal to my 2001 Africa Twin so should be able to help
If you don't want to or can't come to the Ecky Thump and can wait until November let me know
John
Sent from my SM-G960F using Tapatalk
Craggrat
Post by Craggrat »
Thanks guys, see you at Pickering, I did wire it up myself, but the spot light switch burnt out, so disconnected all the wiring I did.
I’m not into electrics, not bad on the spanner’s tho.
AlanHolt
Has thanked: 382 times
Been thanked: 399 times
Post by AlanHolt »
I guess you didn't use a fuse and relay then...
Current bike is a Yamaha T7
Craggrat
Post by Craggrat »
Yes, used relay n fuse, but I wired it up wrong, electrics aren’t my thing.
