Ah I did notice the arrow. If its fitted correctly then the cable block will be behind the front brake lever(it wont foul it though) and when rotated it will point upwards towards mirrors so I presume they fitted it like that so its not behind brake..... bit late to mention it now but will put grips on full to melt glue and try adjusting without screwing them up. Will have to wait till back from work in a few weekslancashirelad wrote:Just nipped out to the garage to see how close mine are to the switchgear they are a bit closer than yours also in your pic the cable to the grip should be perpendicular to the bars if you get my drift they have an arrow on the inner side of the grip to show how they should be fitted, mine is wrong also but at some point I will change it.
