Satnav Coordinates
gbags
Has thanked: 1078 times
Been thanked: 662 times
Satnav Coordinates
Post by gbags »
Hi Techies,
I’ve just been introduced to iOverlander but it uses coordinates instead of locations. I know how to use coordinates on maps but how do I use them on a satnav please?
I’m using a Garmin 390LM but. I suppose they all use the same method to plot them?
Many thanks,
Graham
bowber
Has thanked: 34 times
Been thanked: 179 times
Re: Satnav Coordinates
Post by bowber »
All the satnav's I've had have the option to enter coordinates instead of an address, it's usually under the search address options, you can usually find an option for postcode, address, place name, near here or Coordinates.
Mike54
Has thanked: 18 times
Been thanked: 95 times
Post by Mike54 »
just ensure you're using the same format. easiest is digital ie hhhhh.dddddd
so, 54.33445, 002.44747
the latter is sometimes expressed as a minus eg -2.44747 but you will input it as 002 etc
I wish the whole world used digi coords etc, even for postage.
Fried Egg Sandwich
Has thanked: 180 times
Been thanked: 65 times
Post by Fried Egg Sandwich »
Mike54 wrote: Wed Aug 01, 2018 10:56 amI wish the whole world used digi coords etc, even for postage.
I wish the whole world would use https://what3words.com simple and everyone can understand. A unique easy to read address that pinpoints down to 3m×3m anywhere in the world. (Ideal for deserts, or on water)
Suzuki DRZ400S
BMW R1150GS
Royal Enfield Interceptor 650
gbags
Post by gbags »
Thanks Guys,
Bowser, I’ll look for that.
Mike and Fried egg, I have absolutely no idea what you are talking about but I’ll try to work it out.
I should have said
Hi Techies, please speak slowly and simply.
Thanks again
gbags
Post by gbags »
Hi Mike,
Your coords are up in the Lake District?
The problem is that I have no idea what village or town they’re near. I put the coords into the satnav and that worked, then asked for the route and it showed the route. Can I look that up on, say, Googlemaps, to see where it comes out?
Mike54
Post by Mike54 »
it's just a random point on the map, there's nothing there but a stream.
Try this one, bit more fun. if its not immediately obvious, use street view :lol:
36.073444, -115.956597
chrisjk
Has thanked: 52 times
Been thanked: 156 times
Post by chrisjk »
How would you know where that it Mike? :D
Mike54
Post by Mike54 »
Just an idea I had :lol:
hotbulb
Has thanked: 89 times
Been thanked: 28 times
Post by hotbulb »
good to see there's ample hardstanding!
