HedgeHopper wrote: ↑Mon Jul 30, 2018 4:21 pm
Nope .......a reflected pulse can push unburnt fuel back into the cylinder of a 2 stroke instead of it going straight out the exhaust*, its not a feature in 4 stroke exhausts and if it was it would hardly help draw exhaust out as the pulse is in the other direction
* this happens because the exhaust port and intake port are partially open at the same time
When the positive wave is reversed it changes polarity and becomes an negative wave, these go back and forth reversing all the time and it's the timing of these that 2 strokes take advantage of to good effect but 4 strokes do too, and is why multi cylinder systems have specific lengths and joining points.
You can use a megaphone to help increase the strength of this wave or pulse but at the expense of a very narrow usable rev range (Manx Norton era road racers), adding a reverse cone to this megaphone increases the usable range but reduces the strength.
I have a shelf of books on this subject and used to spend days calculating it all with different valve timings etc for our racing motors, however all of this has been overtaken by computers being used to tune exhausts and motors and along with computer controlled ignition and fueling they can now use valve timings and hugely over square motors that would have taken huge amounts of time to get running properly.
The result of this is that I'd rather run the quiet standard exhaust than a noisy open one as it's works very well, the only benefit would be weight, and my original post stands in that to get the best out of an open system (no baffle) the OP would need to get the motor tuned on a dyno.
