Removing oil residue from aluminium tank
HedgeHopper
Has thanked: 58 times
Been thanked: 174 times
Re: Removing oil residue from aluminium tank
Post by HedgeHopper » Tue Jul 10, 2018 9:37 pm
Is there a specific reason to do this instead of all the other easy ways to carry some water?, could you just use the space for tool storage perhaps?
RichP
Has thanked: 22 times
Been thanked: 40 times
Post by RichP » Tue Jul 10, 2018 10:04 pm
Unfortunately the space is designed just for fluids and it saves having to carry extra bottles etc. and it keeps the weight nice and low.
KTM bashpate.PNG (105.02 KiB) Viewed 954 times
RichP
Post by RichP » Tue Jul 10, 2018 10:07 pm
Benson-1215 wrote:
Tue Jul 10, 2018 5:55 pm
Put salt in it and shake it about and leave for 24 hours add half a cup of water and shake again and leave fill completly with water and leave another 24 hours flush out then let it dry and let the oxidation happen.
coke can also work ( the sugary harmful drink not the white powder one :shock: )
That sounds very scientific and worth a go - thanks very much.
RichP
Post by RichP » Tue Jul 10, 2018 10:09 pm
herman wrote:
Tue Jul 10, 2018 8:03 pm
Would one of those petrol tank sealants work? The kind that coats the inside of the tank and seals the rust and crap in.
That's an alternative worth looking at - i'll have a look and see if it works with aluminium
Mikekitts81
Been thanked: 51 times
Post by Mikekitts81 » Tue Jul 17, 2018 11:14 am
would engine flush not work then use soapy salt water a few times to wash it all out and finish off with apple cider vinegar to give it abit of a wash with a light acid . should get rid of any funny taste . and apple cider vinegar is not as high in acid as stragiht white vinegar so shouldnt leave a horrible vinegar taste once washed out . alot of people use white vinegar in there feul tanks to clean the rust so shouldnt do any harm to it .
Helicoptermanr22
Been thanked: 38 times
Post by Helicoptermanr22 » Tue Jul 17, 2018 6:05 pm
Fill with 1/3 of water and boil it on camping gas stove thing
paul_tim2000
Been thanked: 13 times
Post by paul_tim2000 » Tue Jul 17, 2018 8:11 pm
Do you know anyone with an ultrasonic cleaning bath? If so use whatever cleaning solvent you want to try but fill and seal the tank then put it in the bath, might help remove those ingrained residues deep in the walls.
chunky butt
Has thanked: 49 times
Been thanked: 507 times
Post by chunky butt » Tue Jul 17, 2018 9:03 pm
What about a couple of handfuls of gravel, hot water, plenty detergent, good shake up......or a bottle brush you can bend into all the nooks and crannies, plenty detergent.....hope this helps...
RichP
Post by RichP » Tue Jul 17, 2018 9:12 pm
Thanks for all the tips! I'm trying the salt and water method at the minute. Just added a cup full of water after letting the salt stand for a day. If this doesn't work I've got a few other methods to try. Cheers Rich
Andi_Archer
Been thanked: 118 times
Post by Andi_Archer » Tue Jul 17, 2018 9:46 pm
Given the metal on the tank will be tainted by whatever it contained before can you not once cleaned, install some form of bladder to keep the water in so it wont absorb anything the the tank?
Users browsing this forum: Bing [Bot] and 11 guests
