Triumph Thunderbird 1600
David Harding
Has thanked: 6 times
Post by David Harding » Mon Jul 09, 2018 9:43 pm
Hi,
Could someone pls let me know how often (in miles) you should tighten `belt drive` bike belts?
David
Tourider
Been thanked: 8 times
Re: Triumph Thunderbird 1600
Post by Tourider » Mon Jul 09, 2018 10:19 pm
I've had several Harleys and a Victory. It's more a case of "check and adjust if necessary".
Spike941
Has thanked: 229 times
Been thanked: 110 times
Post by Spike941 » Mon Jul 09, 2018 11:10 pm
Never needed to touch mine on my Electra Glide in the 11 years and 30 odd thousand miles I had it. Virtually maintaince free. From memory, Harley suggested replacing the belt after 70 thousand or thereabouts, although my memory’s not what it used to be, so I could be a few miles out.
prg4967
Been thanked: 22 times
Post by prg4967 » Thu Jul 12, 2018 9:23 pm
Had a thunderbird for a few years, once the belt is set you don’t need to touch them until you change the tyre..which you will do..a lot...can’t remember the specifics but I know they run tight, tighter then a Harley by the book..but I always ran min a little looser, about 1/4 turn..if you get the rear wheel out of alignment buy just a tickle the belt will squeak like crazy...little bit of candle wax on the side of the belt cures it...that’s about as much as I can remember...loved mine but expensive to run...
Users browsing this forum: No registered users and 61 guests
