BMW R1200 GS LC
ollydog
Has thanked: 61 times
Been thanked: 18 times
BMW R1200 GS LC
Post by ollydog »
Gents, having just filled up in Wales with a full tank of fuel, immediately the bike began to miss fire on the button, hum me thinks it cant be the fuel straight off as the old fuel will still be in the system but did check the bill and checked with the attendant.
Limped along and then it cleared its self, got to work then on the way home the misfire the engine management light came on. I managed to clear this my manually reseting the TPS but it got worse. So change the plugs but not checked the clearances yet. Still won't rev at all and sort of ticks over at 2k rpm
Any thoughts
Brads
Been thanked: 39 times
Re: BMW R1200 GS LC
Post by Brads »
Empty tank and refill with what you know to be clean fuel.
Kinda too coincidental to be somit else.
Round the world ???
Round the bend more like !
Has thanked: 330 times
Been thanked: 634 times
Re: BMW R1200 GS LC
Post by Tramp »
Yep save fuel in a clean container, then use super unleaded... If its fine get trading standards to chexk your fuel sample... Was it a rural garage? Or mainstream supwrmarket..... Could be dirt in their tanks if low... So check your fuel filter too.... Hot weather causes condensation in tanks.... Always refill in cool air in morning...
chunky butt
Has thanked: 54 times
Been thanked: 699 times
Re: BMW R1200 GS LC
Post by chunky butt »
Got to be fuel surely, as already said, drain existing fuel and refill with fresh from a good source.....good luck ;)
ollydog
Re: BMW R1200 GS LC
Post by ollydog »
Happened before in Wales on my R1, but managed to get 100m meters down the road before it went tits up and that time it was a plug, this time i was low on fuel so will refresh and check the filters, will keep you posted
ollydog
Re: BMW R1200 GS LC
Post by ollydog »
Just checked, i don't this model has a fuel filter separate from the pump it may be a complete change, anyone know any different
anthony29040
Has thanked: 6 times
Been thanked: 61 times
Re: BMW R1200 GS LC
Post by anthony29040 »
you haven't put diesel in by ant chance.open the cap and smell it,easy done.
Rothy
Been thanked: 14 times
Re: BMW R1200 GS LC
Post by Rothy »
Olly I’ve experienced something similar on mine the last month. It’s happened a few times and usually happens when the bikes takes an extra few seconds to fire up. I thought it was fuel at first but after it cleared it then happened again few week later after refuelling.
It would miss fire and felt like I was running out of fuel every time I tried to open the throttle and couldn’t get it over 50/60mph.
I think my problem is down to a fault on the exhaust flap and recently it must have started sticking maybe??
Anyway I’m booked in for service next week so was gonna mention it aswell.
BMW R1200GS LC
2018 EuropeanTour
2Weeks, 4500miles & 17 Countries
https://spark.adobe.com/page/j7rimGou6IOgR/
ollydog
Re: BMW R1200 GS LC
Post by ollydog »
going to check the valves tonight not done for 9k miles
steve
Hugh
Has thanked: 878 times
Been thanked: 929 times
Re: BMW R1200 GS LC
Post by Hugh »
Greetings Steve,
I am not familiar with the nuances of your model of bike but two thoughts spring to mind, a blocked/kinked tank breather pipe or dirt in the petrol either from sediment being disturbed or introduced. There could be other reasons too but I always go for the last thing to be disturbed or the easiest to be checked.
Initially I would look for a breather pipe which might be a standard piece of pipe or an electrically controlled solenoid type valve. Second job would be to remove the pump for inspection and cleaning. I found this video which might be of interest;
Some injectors do have an inline filter which might need cleaning, check with a BMW service department.
