Hi,
Did anyone here fit a Renthal fat bar on the F800? If so, is it a simple swap or did you have any problems installing bar weights or hand guards due the fact that the Renthal are thicker?
Renthal bars F800GS
- Has thanked: 13 times
- Been thanked: 4 times
Re: Renthal bars F800GS
I did and returned them
You can’t fit the bar ends from bmw as it needs threaded inserts. I considered expansion bolts but sent them back. You also have to drill all your own holes for fitting the grips. Although this may be normal
Yes, that's what I was afraid of. Thanks for your answer. What did you get instead? Did you just stick with the OEM ones?
I got rid of the bike! and brought a BETTER one!!rodrigoscs wrote: ↑Wed Jun 20, 2018 9:18 amYes, that's what I was afraid of. Thanks for your answer. What did you get instead? Did you just stick with the OEM ones?
