Lazy starting !!!
PHILinFRANCE
Has thanked: 1406 times
Been thanked: 766 times
Lazy starting !!!
Post by PHILinFRANCE » Sat Jun 16, 2018 5:52 pm
This has got me proper baffled , the Donks battery is reading 13.3 standing and 14.4 on tick over and holding ,higher on 5k revs , starts fine but as the trip goes on it gets lazier and lazier untill its like a flat battery !!! but i test it and its reading 13 + and 14+ running !!!
Sounds to me like something is braking down as it gets hotter ..................am i miles away with that idea ? but if yes what could it be ?
Cheers Phil
WIBO
Has thanked: 562 times
Been thanked: 626 times
Re: Lazy starting !!!
Post by WIBO » Sat Jun 16, 2018 6:04 pm
Zumo Rays,.....yes, Zumo Rays from Outer Space...........first thing to do Phil is to put your tin foil hat back on.....yes that'll help. Ping a pic to prove you've got it back on then you'll get a better response I'd say.....
:D
Will It Buff Out?
The Suit:What would you consider to be your greatest weakness?
Me: Honesty.
The Suit: Honesty? I don't think honesty could be construed as a weakness.
Me: I don't give a f**k what you think.
HedgeHopper
Has thanked: 58 times
Been thanked: 174 times
Post by HedgeHopper » Sat Jun 16, 2018 6:21 pm
Hope it's not kaput, you'll have to apply for an Explosives Precursors and Poisons (EPP) licence. before you can get a new un
Seriously though,it sounds like it may have been overcharged and vented out the good stuff?...check your regulator perhaps?
diggermanbob
Has thanked: 570 times
Been thanked: 455 times
Post by diggermanbob » Sat Jun 16, 2018 6:41 pm
Is the battery going flat Phil or is it the starter playing up when hot ??
DaveCon
Has thanked: 100 times
Been thanked: 99 times
Post by DaveCon » Sat Jun 16, 2018 6:43 pm
Could be something electrical breaking down. Could also be something mechanically jamming up with heat too. My son, who's a car mechanic, say he's seen car starter motors jam when they get hot. At the time we were pondering a BMW1000RR with the same problem. The cure was to fit a new one 'cos he wasn't paying for it :lol:
Have you had the starter assy. off recently? Try re-aligning the starter when it's hot. ;)
Has thanked: 252 times
Been thanked: 425 times
Post by Tramp » Sat Jun 16, 2018 6:59 pm
If the batts 13.5 non running then 14. 4v at 4krpm the charger is fine.... What does batt reading drop to when lazy starting?... Could be a cell going down underload.... Try again when underload starting with lights on too.... And report back... If it 11v batt is fubared again.... Check connections and earths as its been in bits again...
Park it next to the ktm and do a monty python on it...
zimtim
Has thanked: 569 times
Been thanked: 483 times
Post by zimtim » Sat Jun 16, 2018 7:07 pm
Had similar on the XTZ.
Turned out the reg/rec was knackered it was slowly cooking the battery.
At times you could hear the battery bubbling away and a very strong smell of sulphur.
Had to replace battery and the reg/rec in the end.
How many things do you have on that are drawing power. You could be drawing more than you are generating :roll:
minkyhead
Has thanked: 333 times
Been thanked: 520 times
Post by minkyhead » Sat Jun 16, 2018 10:52 pm
sound like the rectifier ..can you swap out the one from donk 2 ?
PHILinFRANCE
Post by PHILinFRANCE » Sun Jun 17, 2018 7:35 am
Cheers Steve , i did a swap with them a month or 2 back but i suppose it could be that they both are failing they are both over 20 years old
Just tested it this morning and cold and engine off its reading 13 so only dropped 0.3 over night and 14.4 running :?
diggermanbob
Post by diggermanbob » Sun Jun 17, 2018 7:43 am
Might still be the starter lazy when hot , or is the battery actually going flat ?
Users browsing this forum: boboneleg and 31 guests
