Well getting ready to go out on Sunday I was checking over the Beta when both fuses blew Replaced them and they blew too
So seat, tank and side panels off the check the wiring, the loom sheathing looked rather tired but no obvious problems. Anyway decided to strip the outer cover off and found cracks in the protective cover of the wires going up to the ignition switch, so rewired that section back to the fuse box and all then seemed ok.
Put everything back together again and figured I had better just give it another check before calling it a night after three hours of work. Puff the fuses blew again. Enough, look at it again in the morning
Another disconnect of all of the plugs and slowly reconnecting one part of the loom at a time. Still nothing to see but running my hand around the cables at the headstock I noted that the one section of a loom felt to have been crushed. Slit the outer covering and there I found the damaged wires which feed the pilot light and headlight.
Spliced in a new section and now all is well, I hope
I hate electrics and the air in the garage is still 'blue'. Eight blown fuses and a good 7 hours of head scratching tedious work.
Hope your problems are sorted too by now
Electrics !!!!
- Has thanked: 3467 times
- Been thanked: 1823 times
Re: Electrics !!!!
i feel your pain Hugh
BUT thanks to another set of eyes and brain .....................even though they are Dutch my best friend in the WHOLE WORLD, Ard got it sorted in less than an hour
Turns out it was the side stand switch relay "socket " so i wasn't all wrong with another relay tested but Ard pointed out that as i had done away with the whole switch there was no need for the relay and bugger me it worked happy days and as the people who know me i'm all for saftey !!!! YEH RIGHT
- boboneleg
- Has thanked: 2363 times
- Been thanked: 1407 times
Re: Electrics !!!!
Dave Con is da man, although I thought you'd dismissed the diode Phil
one-legged adventurer
- boboneleg
Re: Electrics !!!!
So we're back on for a 3 donkey and one tenner lady tour of the TET
- chunky butt
- Has thanked: 54 times
- Been thanked: 699 times
Re: Electrics !!!!
I bet your on the lash now son......result.....least you didn't have to beat it with big hammer
Re: Electrics !!!!
Ohhhh i've have a bottle of 9 ..........................victory drink ya know
As it turned out , yes Dave con was 90% right but it wasn't the diode or the relay , it was the female end conector that went into the relay
But who give a fuck it works noiw and its 3 Donks to "pasta land" ..........................ohh forgot theres now a Tener lady joining us
