A question for the mighty ABR hive mind......
I was replacing the airfilter in my 800GS over the weekend and I found a set of connectors tucked between the battery and airbox.
I think they're aftermarket (can't find any reference to them anywhere in manuals etc) so wondered if anyone knew what they were.
Theyre on a flying lead and look a bit like 3.5mm phono connections, two of them, one in a hex-shaped housing. can't see where the wiring goes at the moment, but just wondered if any of you thinks "Ah, that'll be.........."
A
Mystery Connector
- Has thanked: 76 times
- Been thanked: 123 times
- Has thanked: 8 times
- Been thanked: 14 times
- Has thanked: 186 times
- Been thanked: 74 times
Re: Mystery Connector
BMW dyanostic port ?
"I came into this world with nothing and with careful management
I still have most of it left'
- Steve T
- Has thanked: 256 times
- Been thanked: 836 times
A photo of the plugs would help ID them
Steve T
Steve T
ZEN DOG
Will try to get a photo and post it up. Some good guesses so far, but I'm pretty sure it's not Zimtim's suggestion. The bike has enough vibration at 70mph to make that kind of kit redundant
So I finally got chance to get the plastics off again last night, here's the enigma.
The cable/connectors are tucked down the back of the airbox, and are connected into the bike's loom via the connector with the yellow wires. The red fused wire is direct to the battery and is for some cheapo aux lights.
Ideas on a postcard marked 'WTF' to the usual addrerss please!
- IMG_20180430_185654.jpg (78.8 KiB) Viewed 3501 times
- IMG_20180430_185634.jpg (91.35 KiB) Viewed 3501 times
- IMG_20180430_185620.jpg (101.64 KiB) Viewed 3501 times
Looking at the three yellow wires going into the BMW connection for the Power to the sat nav
Do you have a BMW sat nav or a Garmin powered mount on your bike ?
If you have it could be part of the loom that comes with it
Try fitting a phono jack into it when you have your sat nav on
Have you had a look which way it heads on the bike
