ANYONE HELP ME KTM LC4 E 640
- Mikekitts81
- Has thanked: 10 times
- Been thanked: 57 times
GOT A KTM LC4 TODAY TOOK IT TO PEICES STRIPPED THE HOLE BIKE APART THEN STARTED TO LOOK AT THE ENGINE AND ON INSPECTION OF TAKING THE COVERS OF THE ENGINE AT THE CAMSHAFT THERES A CLIP WHAT LOOKS LIKE IT SHOULDNT BE LOOSE AND SHOULD BE INPLACE TO HOLD IT ALL FIRM INSTEAD OF HOW MINE IS SEE VIDEO . NOW I NOTICE THERE IS A CLIP ON THE SIDE WHICH WILL GO IN TO THE CAM BUT BY THE LOOKS OF IT THE ENDS HAVE SNAPPED OFF OR IS THAT RIGHT THERE JUST FLAT ENDS WITH NO LOOPS TO GRAB WITH THE PLIERS ....
- Has thanked: 2 times
- Been thanked: 83 times
Re: ANYONE HELP ME KTM LC4 E 640
Not familiar with that model but i had a 450 exc. So that end bearing on the left of video that sits on the end of the cam shouldn't be so loose. It's most likely a wore cam end. You could bodge it by pock marking the cam journal...... unless it's a plain bearing design and runs on a oil film which will then ruin it lol! Just behind the cam sprocket does that ring fit into the slot on head to hold bearing/cam in place? Hard to make out.
Yamaha tenere 700
Just looked at it again and I'm sure that loose ring fits into the slot by bearing that I can see which will stop everything moving about.
Yamaha tenere 700
- AlanHolt
- Has thanked: 382 times
- Been thanked: 398 times
At 33 seconds, its clear to see the groove that the lose clip should sit in to keep everything in place. You've got less movement in the auto-decompressor than I found on mine.
Current bike is a Yamaha T7
- Has thanked: 1048 times
- Been thanked: 194 times
Mike, If you haven't got a repair manual, PM me your e mail address and I can send you one.
Time knows no limits for days such as these.............
- Mikekitts81
Thanks I will do ..
- Mikekitts81
thankyou ian for the manuals they were great much appreciated ...
since getting the manuals i have been looking through and have started to create the running only wiring in colour but i cant seem to figure out what the use for number 12 is ... its the combnat switch in the red circle
- Mikekitts81
forget that last post been looking at this screen to long ...its the switchs for the lights etc ... lol my bad
