Stupid meeeee!
Cone
Has thanked: 156 times
Been thanked: 252 times
Stupid meeeee!
Post by Cone »
So the other day i was removing the risers i put on the bike and checked the old bars for trueness against a new set..
All good, but whilst putting on the electronics on the left hand side of my f800 it was a bit tight so i thought, well just give it a bit of a shove... it'll be all right
Today (a whole day later) the main beam stopped working...
Well looks like i pushed the switch off the flexible pcb.. No main beams ever!!
No then, no one seems to be selling a second hand on and i have an mot coming up soon. Found ones for sale in the USA for £150 second hand without the ESA etc that I have...
Anyone have any clever suggestions for mending this.............
Craig-SM
Has thanked: 27 times
Been thanked: 42 times
Re: Stupid meeeee!
Post by Craig-SM »
Not familiar with the BMW switch gear but try taking it to an auto electrician.
Cone
Re: Stupid meeeee!
Post by Cone »
Cone
Re: Stupid meeeee!
Post by Cone »
Can’t believe it 177 pounds for the part just over that little switch.
https://www.bmw-motorrad-bohling.com/uk ... 2-k75.html
Could an auto electrician solder to that flexible pcb.. ?
Hugh
Has thanked: 878 times
Been thanked: 929 times
Re: Stupid meeeee!
Post by Hugh »
Perhaps a switch from another motorcycle might be substituted or the original repaired by an electrician or computer technician.
Might I suggest that you could find a specialist breaker to guide you, such as;
https://www.motorworks.co.uk/vlive/Home/index.php
I don't know the named company, only found them on the internet.
Benson-1215
Has thanked: 186 times
Been thanked: 74 times
Re: Stupid meeeee!
Post by Benson-1215 »
Cone wrote: Tue Mar 13, 2018 9:19 pm 7BEC70C2-F57B-457E-93AB-E590A01E293E.jpeg523AA725-1278-47A9-97B8-12BC821320C8.jpeg
Hi Cone can you flip the first picture over please?
I am sure my mate has done one of these before :D
"I came into this world with nothing and with careful management
I still have most of it left'
bikenav
Has thanked: 1187 times
Been thanked: 761 times
Re: Stupid meeeee!
Post by bikenav »
If trying to source second hand - the switch gear is possibly common to other models my gs12 switchgear is anyway.
Cone
Re: Stupid meeeee!
Post by Cone »
Thanks but mine has ESC ABS etc... so there not compatible..
Benson-1215 wrote: Tue Mar 13, 2018 10:22 pm
HOW? getting a picture up there was an acheivement!! :D
catcitrus
Has thanked: 95 times
Been thanked: 448 times
Re: Stupid meeeee!
Post by catcitrus »
Far too delicate for a bike that will be used offroad!--is all that delicate complexity because of canbus?--whatever happened to simple sliding contacts and properly clamped cables like a normal 3 pin plug?--anyway--good luck on fixing it.
