Placky tank screws
- Has thanked: 3467 times
- Been thanked: 1823 times
Re: Placky tank screws
Got it sorted €2.80 from local shop , they were a bit long but ground em down and the tanks got 5 ltr sat in it with the tap off and no leaks
As I said Phil, check with your local KTM dealer first, most parts are sensible prices and it's not worth messing about.
I got a bolt kit for KTMs and it came with all the silly little bolts you loose or need to replace occasionally, including the sprocket bolts n nuts.
Check your rear sprocket bolts regularly as they can come loose and bugger the hub.
Oh, and mine does around 60mpg including trails but if I'm with my mates and get pushing on it can drop to low 40s.
Cheers Steve ,what sprocket sizes you running ?
I run 14:48 but I'm thinking of fitting a 50 on the back as I don't hit top gear much on the road, got to be doing 55+ before top becomes usable so maybe a tad over geared
Smashing .......hard wear shop screws worked , no leaks
Was it you that was looking for a big tank Steve ? anyway theres these
https://www.leboncoin.fr/equipement_mot ... tm?ca=12_s
