Okay i was out for a short ride on the ccm644 ..it survived lol anyway as it didnt have the sumpguard fitted I noticed how quite it was...
So I thought of using some of the closed cell camping matt foam between top of guard and underside of engine....
Will it melt or catch fire ..was just going to pock some mounting holes in it ....
sump guard soundproofing .?
Re: sump guard soundproofing .?
You could use the sleep mat but I would give it a covering with something like this just incase
https://www.demon-tweeks.co.uk/motorspo ... d-material
Besides I thought you had had enough of the yellow peril letting you down and were going to sell it and buy something you could trust to finish a trip
- Has thanked: 95 times
- Been thanked: 448 times
You don't want closed cell--open cell so that the microchambers are connected--but it will simply fill with mud anyway----if its aluminium then its like ringing a bell--plastic or a carbon composite will be a bit quieter--but any smooth surface will reflect sound waves. Personally, on an offroad bike , I think its a waste of time--and I make carbon bashplates!!
- Has thanked: 2452 times
- Been thanked: 3293 times
I use this stuff:Tramp wrote: ↑Sun Dec 31, 2017 3:20 pm Okay i was out for a short ride on the ccm644 ..it survived lol anyway as it didnt have the sumpguard fitted I noticed how quite it was...
https://www.ebay.co.uk/itm/NEW-SUMP-FOA ... xy0NtTFxGF
but I use it mainly for preventing mud build up between engine and bash plate. Makes the bike easier to clean each time. It just cuts to size, you re-use the same piece for years and it washes up perfectly. I'm not sure that it makes things any quieter though Russ. Might work well in combination with your camping foam idea.
Cheers Guys.....ill try and see what happens....understand about the closed cell open cell stuff ...
Zimtim...I will have you know the ccm only broke because the auot camchain adjuster failed its got a manual one know ...other time it came back in a van was the rider broke ....and its half ktm
- Has thanked: 2280 times
I think its best to leave a clear space .. for air cooling effect. and water flow?
Also the stone pings are good feedback?
- Has thanked: 803 times
- Been thanked: 534 times
Russ ask Phil what we fitted on the Donk , that worked wellTramp wrote: ↑Sun Dec 31, 2017 3:20 pm Okay i was out for a short ride on the ccm644 ..it survived lol anyway as it didnt have the sumpguard fitted I noticed how quite it was...
- boboneleg
- Has thanked: 2363 times
- Been thanked: 1407 times
Yeah but it’s the CCM half that lets you down
Happy new year Russ
one-legged adventurer
- Been thanked: 126 times
