helicoil and drillout costs?
Has thanked: 448 times
Been thanked: 685 times
Re: helicoil and drillout costs?
Post by Richard Simpson Mark II » Sun Nov 26, 2017 6:16 pm
So how does that work when they broke flush to the surface of the cylinder? How can you weld a steel nut to the stud in that situation?
steve the grease
Has thanked: 6 times
Been thanked: 70 times
Post by steve the grease » Sun Nov 26, 2017 6:45 pm
You weld down the midle of the nut onto the end of the stud until the weld fills the hole up . The weld won't stick to the ally.
Lidl/Aldi/ Machine mart etc sell left hand drill stud extractors which are also good , you carefully drill down the midle of the bolt and the anti clockwise drill rotation tends to unscrew the busted stud.
' Easy outs' are terrible things which inevitablty spread the broken stud tightening it .... and then snap.
Has thanked: 556 times
Been thanked: 465 times
Post by zimtim » Sun Nov 26, 2017 6:59 pm
Sun Nov 26, 2017 5:04 pm
I've never got an easy-out to work...screwing them in seems to force the stud to expand and wedge itself tighter into the female hole (sorry, that sounds a bit rude :oops: )
Had good results over the years with easy outs.
People tend use ones that are to big whatever size you think you need go down one size. Thing is to make sure you can get it in deep enough.
It is easier to defend yourself against a thousand enemies, than it is to defend against one backstabbing friend
Billy Bananahead
Has thanked: 48 times
Been thanked: 114 times
Post by Billy Bananahead » Sun Nov 26, 2017 7:28 pm
A few pictures of stud extraction using welded nuts. Ooer.
P1010001 (11).JPG (146.19 KiB) Viewed 943 times
Billy Bananahead
Post by Billy Bananahead » Sun Nov 26, 2017 7:31 pm
Back to front pictures.
Bottom picture is the offending broken stud, flush with the cylinder head, second is the welded nut as a "blob" very hot, camera couldn't really see it, and the third is the extracted stud. Engine is my 2013 Tiger 800XC.
Has thanked: 1089 times
Been thanked: 423 times
Post by garyboy » Sun Nov 26, 2017 7:51 pm
yep .. go for the expert !! ^^
welding, as shown and described on here, is much harder than it looks,
and I have tried drilling into a 6mm bolt set in ali .. almost impossible for the home bod,
the surface of the bolt will not be flat, .. almost impossible to drill centrally and squarely with a hand drill, not to mention the violent centre punch thing.
then a `small drill bit` .. it just wont happen will it (breaks, jumps, rips u finger off)
and then .. whumping a hardened steel anti wotsit thread destroyer exterminator bit into that poor innocent little bolt,
nah .. not going to work unless you are a mechanic or screwing expert :D
best get it done with an engineering chappie, (like the nice fellas on here)
dearer is cheaper in the end 8-)
videoman
Has thanked: 56 times
Been thanked: 9 times
Post by videoman » Sun Nov 26, 2017 8:58 pm
I think every method has already been suggested and I would usually try a left handed cobalt drill first if the bolt has not corroded in the hole. Easi-outs are all well and good if you have a good quality set and are very careful with them. I've always found the smaller the diameter bolt to get out the more difficult it can be and out of the dozens I have removed I never particularly enjoyed this aspect of the job but I have always managed one way or another to remove a sheared bolt. I would say if you take it to a local engineering company an average price would be £25/£30 per bolt to remove.
I have been running a mobile thread repair business for the last seven years and try standing under an expensive Porsche 911 trying to drill out a sheared exhaust manifold bolt or a concours E type Jag will test your nerve and resolve.
Good luck
bowber
Has thanked: 16 times
Been thanked: 127 times
Post by bowber » Sun Nov 26, 2017 11:21 pm
Easy outs for small bolts need to be thrown away, there is nothing easy or out about them!
Left hand drill bit and they quite often come loose before you're up to size, failing that you have to get close to size (hope you were accurate with your centre pop) and then start with a small chisel or screw driver to knock the top edge in all around while adding a slight unscrewing direction.
The heat from drilling helps and then the shrinkage from the middle being missing should also release the thread a little.
Using a drill guide bolted to the surface helps stop the drill wandering but again you need to have been accurate in it's setup.
Hope that makes sense as I've had a few glasses of vino tonight.
Users browsing this forum: Rallyx and 50 guests
