ccm woes update thread
Has thanked: 252 times
Been thanked: 422 times
Post by Tramp » Sat Nov 04, 2017 2:39 pm
Okay got the head off today and 4 bent valves....piston is fine.
So its off to a mate on ccm forum for new valves and seals also got new camchain to go in and a manual adjuster as looks like the gods in france caused the camchain adjuster to go and hence the kiss it goodbye lockup :lol: ...
Its rare for this to happen apparently on ccm but hey im kinda special :D :o ....
daveuprite
Has thanked: 1017 times
Been thanked: 1281 times
Re: ccm woes update thread
Post by daveuprite » Sat Nov 04, 2017 2:45 pm
Glad you got to the bottom of it Russ. Good luck with the fix.
Best wishes, Dave R
PHILinFRANCE
Has thanked: 1351 times
Been thanked: 720 times
Post by PHILinFRANCE » Sat Nov 04, 2017 3:15 pm
Sound like you got off farely light mate , good luck with the fix
diggermanbob
Has thanked: 559 times
Been thanked: 452 times
Post by diggermanbob » Sat Nov 04, 2017 3:33 pm
Hi Russ glad you found the problem , it was what we thought it might be you were lucky with the piston , catch up soon :)
Post by Tramp » Sat Nov 04, 2017 4:16 pm
The dark side said do a 710cc conversion the wife said ...no....lol
Once again thanks for the help and support...only hit my hand twice with hammer and lucky ive only got 8 nuckles lol
micksea
Has thanked: 25 times
Been thanked: 57 times
Post by micksea » Sat Nov 04, 2017 4:29 pm
no point bending just one valve :mrgreen: is the big bore kit much more expensive than rebuilding your own cylinder head? might be worth checking
chunky butt
Has thanked: 48 times
Been thanked: 471 times
Post by chunky butt » Sat Nov 04, 2017 4:41 pm
Glad you've got to the problem russ, could of been a lot worse than valves, good luck with the fix :D
~ACP~
Has thanked: 131 times
Been thanked: 67 times
Post by ~ACP~ » Wed Nov 08, 2017 2:03 pm
Blimey! No wonder it wouldn't start :o
Hope the rebuild goes well. Up for a test ride whenever you're ready ;)
bowber
Has thanked: 16 times
Been thanked: 126 times
Post by bowber » Wed Nov 08, 2017 7:25 pm
Hope you're taking the barrel off to check the piston, sometimes the rings get trapped.
I once had a cam belt snap on a Rotax motor and amazingly the valves didn't hit, god knows how as it had a big bore high comp piston and big cam in it.
Post by Tramp » Wed Nov 08, 2017 8:59 pm
Right folks....the head has had 4 new valves and oil seals fitted by a mate and a exhaust stud removed...its winging its way bak to me...the piston is fine :D ...ive a new head gasket to fit just need to get 4 new copper compression washers for the head bolts...
Ow and a torque wrench too as im hamfisted :lol:
Users browsing this forum: No registered users and 94 guests
