non running fixer upper!
- Has thanked: 419 times
- Been thanked: 158 times
So i bought a non running 2005 Husqvarna te510 as a fixer upper semi project. I thought the reason for not running was mechanical and have now checked the timing,which is all in sync,also the valve clearances are fine and the carb is all clean and doing what is supposed to do! But the bike still won't fire up.
I got all the things i have checked confirmed by a mechanic just to make sure I've done it all properly and he did a pressure and leak down test as well, and the results were ok. So i know i have compression, fuel, a good spark, but the bike just keeps turning over but wont fire up! So the issue must be electrical, and this is where I'm stumped, as i have no clue when it comes to electrical stuff. Could the spark be sparking at the wrong time? What part of the circuit is it that tells the spark when to fire?, can it be tested and how?
Im pulling my hair out over this now and just don't know how to fix this, ive trawlled through you tube videos but none seem to highlight my problem,so any experts out there please please help before i go insane.
- Has thanked: 1414 times
- Been thanked: 1669 times
Re: non running fixer upper!
Firing on the wrong stroke....BTDC of the exhaust stroke rather than the compression stroke?
If it's any consolation I had a TE610E which was a poor starter too.
- Has thanked: 116 times
- Been thanked: 270 times
The pick up coil 180° out or ignition coils on the opposite plugs. Is it a twin or single?
- HedgeHopper
- Has thanked: 58 times
- Been thanked: 174 times
Remote diagnosis is a mug's game, but just to completely elimanate Fuelling: pull the plug out, drop a teaspoon of fuel down the 'ole plug back in and give er a try
- Has thanked: 2280 times
yeah .. I think its fuel ... turn over a few times then check if the spark plug is wet .... if dry then no fuel getting through .. if very wet then it is flooding ... if a bit wet then its probably ignition after all?
(ps.. no expert)
(ps.. no expert)
I wouldn't put raw fuel in the engine unless you are sure the timing is spot on...if it fires at BDC it won't be pretty (just ask the guy who muddled the plug leads on his Ducati).
Squirt of easy start might be better
Its a single! Is it the coil that controls the actual spark timing?Billy Bananahead wrote: ↑Sat Oct 28, 2017 9:51 am The pick up coil 180° out or ignition coils on the opposite plugs. Is it a twin or single?
Thanks for that. I might try easy start, but surly the garage would have tried that! Ill check with them first.Richard Simpson Mark II wrote: ↑Sat Oct 28, 2017 11:39 am I wouldn't put raw fuel in the engine unless you are sure the timing is spot on...if it fires at BDC it won't be pretty (just ask the guy who muddled the plug leads on his Ducati).
- HedgeHopper
Ducati has a 90 degree difference between firing of each cylinder, so swapping leads is BAD.Richard Simpson Mark II wrote: ↑Sat Oct 28, 2017 11:39 am I wouldn't put raw fuel in the engine unless you are sure the timing is spot on...if it fires at BDC it won't be pretty (just ask the guy who muddled the plug leads on his Ducati).
There is nothing to worry about in putting a teaspoon of fuel down the plug ole of a 500cc single even if the spark is 180 out.
(it's not enough to hydro lock it either)
There will be some sort of trigger or rotor on the end of the crankshaft that passes the electro-magnetic pick up coil. If the trigger or coil is in the wrong place the spark will fire at the wrong time.dibbs wrote: ↑Sat Oct 28, 2017 12:52 pmIts a single! Is it the coil that controls the actual spark timing?Billy Bananahead wrote: ↑Sat Oct 28, 2017 9:51 am The pick up coil 180° out or ignition coils on the opposite plugs. Is it a twin or single?
I'm only guessing as that is how most bikes work these days.
