Using Sat Nav
Rederic
Has thanked: 31 times
Been thanked: 133 times
Using Sat Nav
Post by Rederic » Tue Mar 14, 2017 9:54 pm
I have just been looking at this in the MCN
http://www.motorcyclenews.com/news/2017 ... s-driving/
And cannot get my head around what is meant by 45 degrees, (who would put it by the elbow)
and if its bolted to the bike is it still classed as a mobile device ?
[center]
[/center]
boatman
Been thanked: 2 times
Re: Using Sat Nav
Post by boatman » Tue Mar 14, 2017 10:07 pm
One will be studiously ignoring anything to do with this
TomBoyNI
Been thanked: 38 times
Re: Using Sat Nav
Post by TomBoyNI » Tue Mar 14, 2017 11:25 pm
With the failure to have control of a vehicle offence, using a sat nav could always potentially land you in a spot of bother.
Boo :-p
http://tbni.blog
diggermanbob
Has thanked: 560 times
Been thanked: 452 times
Re: Using Sat Nav
Post by diggermanbob » Wed Mar 15, 2017 7:03 am
Christ I spilt my cuppa all down my shirt , :laugh: I do love your posts :whistle:
AlanHolt
Has thanked: 235 times
Been thanked: 279 times
Re: Using Sat Nav
Post by AlanHolt » Wed Mar 15, 2017 8:38 am
Is it an adventure if you are guided turn by turn to a predetermined end point?
-Ralph-
Using Sat Nav
Post by -Ralph- » Wed Mar 15, 2017 8:40 am
No the sat nav in a cradle is not hand held, not covered by the 6 point £200 fixed penalty.
If you tap "Destination", "Home" on the Sat nav you'll be absolutely fine, no different to resetting your trip meter or switching on your heated grips.
Start plumbing in street addresses and be seen by a copper doing it, and expect to land up explaining yourself in court.
-Ralph-
Using Sat Nav
Post by -Ralph- » Wed Mar 15, 2017 9:02 am
PS: the 45 degree thing gives 22.25 degrees below your level line of sight and your Sat nav shouldn't be above that line. It's a technical thing for use in court to determine non compliance, coppers don't carry a spirit level and a protractor
It's a load of bollocks because on a large adventure bike with a short rider your speedometer might not comply with that.
Basically just don't put it anywhere that it obscures your view of the road ahead. On your bars, triple clamp, on your tank, or between the top of your speedo and the bottom of your screen.
Some bikers have it mounted at the top of the screen, where it could be argued it obscures your vision, but a copper is never going to argue about it unless he's stopped you for other offences and one of you is being a prick.
jonny955
Re: Using Sat Nav
Post by jonny955 » Wed Mar 15, 2017 9:11 am
-Ralph- wrote:PS: the 45 degree thing gives 22.25 degrees below your level line of sight and your Sat nav shouldn't be above that line. It's a technical thing for use in court to determine non compliance, coppers don't carry a spirit level and a protractor
Sensible advice, there Ralph.
I see many cars with their huge 'mobile' devices suckered on to the windscreen just below the mirror or next too the already wide A pillar. You can bet your bottom dollar they are not simply used for sat-nav purposes because they are close enough to read texts & social media as it pings in.
Jon
AlanHolt
Re: Using Sat Nav
Post by AlanHolt » Wed Mar 15, 2017 9:19 am
It's common sense, if a car can fail it's mot for having a chip in the screen the size of a 50p coin, you can't get away with putting something the size of a satnav there.
Andi_Archer
Has thanked: 3 times
Been thanked: 111 times
Re: Using Sat Nav
Post by Andi_Archer » Wed Mar 15, 2017 9:23 am
Strangly enough a trawl of Google and .Gov seems to give little new guidance on fixed gps use only mentioning if installed on a mobile phone it must be in a cradle not hand held.
I cant for the life of me see how they came up with a 45 degree quote or the logic behind it.
Users browsing this forum: Asgard, Bing [Bot], Desmo, Google [Bot], lancashirelad, Magnon and 55 guests
