Fuel pipe
Fuel pipe
Changed the fuel lines on the 690, the main feed is 8mm so ordered some new 8mm pipe & jubilee clips but it weeps from the clips. The clips are the right size & done up tight so my question is are there fuel injection specific hoses & clips? If so where's best to get them from?
- Has thanked: 1 time
- Been thanked: 5 times
- Has thanked: 1404 times
- Been thanked: 652 times
Re: Fuel pipe
Jubilee clips are rubbish because they do not allow an even clamping pressure due to the flat section under the screw, this leaves the possibility of air being sucked in or feul to leak out. There are specific feul pipe clips which are much better, look on eBay or your local motor factor.
Re: Fuel pipe
Basically mate I've put a Golan fuel filter on & noticed all the lines had started to become britel and had cracks on.Uncle Buck wrote:I have no idea. But I am curious why you had to change them.
Re: Fuel pipe
Yes mate, I've got this type on the fuel taps on the two front tanks. Everything with the 6mm bore is fine it's the 8mm from the fuel pump onward that's the problem I'm guessing the new pipe I've bought is expanding under pressure & as said the clips I've got don't help. Been doing some reading & there's a difference between injection and non injection fuel line.... found a place that specialise in hose & clips just so will give them a call after Christmas.KTMBLAG wrote:
Have you tried this sort Jim
Have a good one mate....
Re: Fuel pipe
Ordinary fuel line isn't designed for fuel injection systems and will fail fairly quickly. The proper fi fuel lines are reinforced to withstand the pump pressure
- 92kk k100lt 193214
- Has thanked: 51 times
- Been thanked: 155 times
Re: Fuel pipe
You need pipe for fuel injection and you need to know the working pressure of the fuel pump as opposed to the injectors because there will be a fuel pressure regulator to reduce the pressure for the injectors. My own bike uses an 8mm inside diameter/13mm diameter.
You also need those clips.
Re: Fuel pipe
Thanks for all the informative responses on this, the 690 fuel pump kicks out 3.3-3.7 bar so now have the information for the suppliers & thinking of using O clips & the clips above for the 3no fuel taps..
