Lowering Suspension - Rear Shock
NeilEvans
Post by NeilEvans »
Hi
I'm looking to lower my KTM 690 by an inch by lowering the rear shock.
Can anyone recommend a suspension specialist within say 50 miles of Southampton?
Famous
Re: Lowering Suspension - Rear Shock
Post by Famous »
Is there a specific reason for lowering the shock as opposed to fitting a new link?
Sorry if I'm not giving you an answer
Trevor Twobikes
Been thanked: 24 times
Post by Trevor Twobikes »
Lowering the bike by fitting a link is a fudge and possibly dangerous as it does not
reduce the suspension travel and that could result in contact with the mudguard. The
correct way is to dismantle the shock and place spacers in to reduce the travel. The same should also be carried out at the front end to retain overall balance and not
simply slide the forks up through the headstock for the same reason. The alternative
is to fit a lower seat if available.
Trevor
cocker
Been thanked: 3 times
Post by cocker »
i think i could do with an inch off my 690 too north yorks area,
Has thanked: 330 times
Been thanked: 634 times
Post by Tramp »
Why only a inch on rear...this woule make front high...cant you drop front forks and reduce the preload ...
But id rather have a proper settup and have high bike and drop a cheek lol...
How about trevor pope Gosport or husky dealer up winchester way...may be able to help you out...
[email protected]
Post by [email protected] »
I've had Rev's Racing do some work like this in the past.
They fail the 'within 50 miles of Southampton' test being in Halesowen.
SteveW
Has thanked: 265 times
Been thanked: 264 times
Post by SteveW »
cocker wrote:i think i could do with an inch off my 690 too north yorks area,
Cocker......Reactive Suspension just North of York. Nowhere better.
Mike54
Has thanked: 18 times
Been thanked: 95 times
Post by Mike54 »
Cut the seat down. None of these bikes are meant to be lowered in terms of their geometry
ToastedBlue
Post by ToastedBlue »
lowering the back by 1 inch will only lower the seat by "about" 1/2 inch at the front
you need to lower the front end too to get the desired change in seat height (thumbs)
Crossrutted
Has thanked: 71 times
Been thanked: 178 times
Post by Crossrutted »
Trevor Twobikes wrote:Lowering the bike by fitting a link is a fudge and possibly dangerous as it does not
Trevor
I was under the (possibly mistaken impression)that fitting a link altered both the suspension rate and travel?? (As the length/geometry of the link arm governs both of these.)
(Clearly it doesn't alter the shock absorber/damper characteristics)
