Tenere XTZ 600 dash dead intermittently
scottnet
Post by scottnet » Tue Mar 15, 2016 9:00 am
Hi, looking for a steer in the right direction. Just recently when I turn the ignition key on the Tenere nothing happens , and when I turn it off I get some activity on the dash for a second or two. I try a few times and it comes on, a jiggle of the key in the barrel does nothing and because there is activity when I turn it off I don’t suspect the ignition switch .
After a few times it all comes to life and all is well. It seems to be worse when it’s cold
Is it possibly the main relay that has a bad connection or is faulty ?
Any ideas greatly appreciated
DaveCon
Has thanked: 100 times
Been thanked: 99 times
Re: Tenere XTZ 600 dash dead intermittently
Post by DaveCon » Tue Mar 15, 2016 9:03 am
When I had this kind of fault on a Triumph it was a duff battery :(
AndyB
Post by AndyB » Tue Mar 15, 2016 9:21 am
I'd check the battery terminals before going any further. Disconnect it then clean and grease everything with good quality silicon grease before reconnecting.
After that just go through the wiring harness from switch backwards and keep cleaning/greasing everything as you go. Intermittent faults are always the worst to clear up so good luck with it.
motorbike
Has thanked: 6 times
Been thanked: 29 times
Post by motorbike » Tue Mar 15, 2016 9:22 am
try xt.660 .com they can be very helpfull
bull
Post by bull » Thu Mar 17, 2016 1:20 pm
maybe dirty contacts in the ignition barrel causing problems
scottnet
Post by scottnet » Thu Mar 17, 2016 1:21 pm
Thanks for all the replies seems like a strip down of the ignition switch is a good place to start
bull
Post by bull » Thu Mar 17, 2016 1:30 pm
well I wouldn't do that just yet, because it might be only something small causing the problem, like a loose or dirty connection or maybe as said already a bad battery etc
Users browsing this forum: No registered users and 55 guests
