.....contribute B)
Here's the synopsis, the bike is a DRZ400s W/2000 model. Went to start it, nothing! just turned over, managed to bump start it and the bike wouldn't idle.
The problem now is the bike will start, but when it gets warm and the revs are below 2000/1800 it just bogs out, and then won't start for another 20 minutes.
Here's what I've tried so far.
Changed the plug
Checked the spark
Changed the fuel
Cleaned the carb
Checked manifold rubbers
Replaced the carb
Re-set the ignition advance on carb
Checked valve clearances
Checked cam chain / tensioner
Replaced CDI unit
Edit - also checked the compression.
- runs smooth, sounds right just dies at idle rpm when warm.
Rapidly running out of ideas :S and money :whistle: . So any thoughts greatly appreciated (thumbs)
Armchair mechanics wanted, DRZ specialist may also....
Re: Armchair mechanics wanted, DRZ specialist may also....
Search YouTube for drz problems by a guy called Jonny cactus he had a similar problem with his bike sorry I can't do a link cos I'm on my phone at work
- Has thanked: 1177 times
- Been thanked: 727 times
Have you had the sides off? Is the engine sounding alright when its running?
Suzuki DR200 Djebel.
When it's running the engine is as smooth as you like, it just won't idle when warm/hotBrenhden wrote:Have you had the sides off? Is the engine sounding alright when its running?
check for an air leak stewie spray a bit of carb cleaner around carb mounts ect just a thought
